Hi everyone!
I have one m2ts to edit, it has some corruped frames in it, atleast rendering in Vegas stops at a certain frame and the file itself makes Vegas to though really long on certain places. So is there a way to fix it up, clean it up, replace the bad frames with blank ones etc? Audio seems to be ok, audio peaks show up fine, no gaps anywhere, so it seems like all the material is there, but some error in frame chain or something.
And suggestions?
make subclips before and after the "bad spot". cutting it out is about all you can do. should lose maybe a 1/2 second as it's long gop video.
any chance to recapture the source again? otherwise stretching out the timeline and looking for blank missing frames is about it.
the only thing i've found is to open it in the trimmer, and not put it on the timeline. cut a good piece, put it on the timeline, smart render it to a new name, piece1, piece2, etc., and then re-assemble the pieces on the timeline. thankfully i haven't had much experience having to do this.
Try using Videoredo to cleanup the m2ts file ... I do believe the 15 day version will do that for you.
Trying to fix a .mov that was corrupted after using undelete software
By Elderain in forum Newbie / General discussionsReplies: 10Last Post: 11th Oct 2012, 13:47 -
m2ts PIDs / NALs fix?
By vato76 in forum EditingReplies: 2Last Post: 27th Aug 2011, 04:35 -
I have a corrupted Quicktime MOV file I need to fix.
By Videogamer555 in forum RestorationReplies: 0Last Post: 5th Mar 2011, 01:51 -
corrupted m2ts file - "cannot detect stream type"
By ac1j2 in forum Newbie / General discussionsReplies: 0Last Post: 4th Mar 2010, 08:51 -
how to fix a corrupted file?
By sharmine in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2007, 18:03
