After browsing the forum extensively I decided to start yet another post on the mts log and transfer issue.
When i Log and Transfer the mts files from the AVCHD folder only the files shorter than 5 minutes will finish succesfully. Longer files will seem to work, but right at the very end it stalls, and i get an unknown error message.
Does anyone know what is happening here, or is the only solution to convert the files using an external program?
thnx,
Marije
I never encounter this
I edit in FCE but I manly use iMovie to capture my mts files from camcorder (try it to capture
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam. -
Thanks for your reply! I think it is the setting of my external harddisk: it is probably FAT32 formatted. I will now search for a way to unformat this!
corrupt .mts file (incorrect length)
By sandergoorden in forum Video ConversionReplies: 55Last Post: 30th Apr 2015, 09:56 -
How to merge multiple .mts files (canon HF) into one single .mts file
By frmsuv2van in forum Video ConversionReplies: 15Last Post: 5th Sep 2014, 22:21 -
Corrupt .mts file problem - length too short
By nlmts in forum Video ConversionReplies: 0Last Post: 2nd Aug 2010, 18:16 -
HD Cam wrote .mts files to my flash card but put in another cam still mts
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Dec 2009, 07:15 -
Vosonic @ the limit of multimedia harddisk players with cardslots? mts?
By innovator in forum Portable VideoReplies: 0Last Post: 20th Jun 2009, 18:19
