http://movies.apple.com/ipad/guided-tours/
I was just wondering. The videos load quickly, are big and super crisp. Would love to use this encoding on my websites. I understand it's .mov and some form of quicktime. If anyone has more details or ideas how they made this please let me know!
I would be happy with other video formats too. I just think I was never able to create an h264 encoded mp4 that loads so quickly and looks so crisp.
Results 1 to 21 of 21
The way you get videos that look that crisp is by starting with high quality source. That means a high quality HD camera, a tripod, proper studio quality lighting - basically professionally shot material.
The actual specs for the facetime video are
The video has been resized to 1:1 PAR NTSC widescreen resolution, and encoded at a relatively high bitrate for that resolution. To put it in context - those specs applied to a 90 minute movie would give you a 2GB filesize.Code:General Complete name : x:\xxxxxx\xxxx\xxxxxxxxx\apple-ipad2-guidedtour-facetime-us-20110308_r848-9cie.mov Format : MPEG-4 Format profile : QuickTime Codec ID : qt File size : 27.3 MiB Duration : 1mn 13s Overall bit rate : 3 123 Kbps Encoded date : UTC 2011-03-10 13:28:09 Tagged date : UTC 2011-03-10 13:28:11 Writing library : Apple QuickTime Media/UUID : 8F43896F-B398-40CD-A9A4-A7B2FAA13658 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.0 Format settings, CABAC : No Format settings, ReFrames : 2 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 1mn 13s Duration_LastFrame : 3s 545ms Bit rate mode : Variable Bit rate : 2 866 Kbps Width : 848 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 fps Resolution : 8 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 0.294 Stream size : 26.1 MiB (96%) Language : English Encoded date : UTC 2011-02-27 21:28:05 Tagged date : UTC 2011-03-10 13:28:11 Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Audio ID : 3 Format : AAC Format/Info : Advanced Audio Codec Format version : Version 4 Format profile : LC Format settings, SBR : No Codec ID : 40 Duration : 1mn 13s Bit rate mode : Constant Bit rate : 125 Kbps Nominal bit rate : 128 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Stream size : 1.09 MiB (4%) Language : English Encoded date : UTC 2011-02-27 21:28:10 Tagged date : UTC 2011-03-10 13:28:11 Menu ID : 2 Encoded date : UTC 2011-02-27 21:28:05 Tagged date : UTC 2011-03-10 13:28:11 Bit rate mode : CBR
As for fast loading and serving - if you had Apple's budget, you could do that too.Read my blog here.
You are awesome guns1inger! Thanks a lot! What software did you use to get the movie details? And how did you get the movie?
I tried to get it with jdownloader but it just showed me the some startup.mov and not the real video. -
Mediainfo or avicodec would tell you the file details.
Streamtransport or quicktime pro would you get the file - quicktime pro is required to save quicktime videos directly from a websites quicktime player. Streamtransport does it differently.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Yeah, that's no problem. We shoot with HD cams (5D Mark II) and edit the videos ourselves. I was just amazed by the loading speed of those videos. I'm in Thailand right now and even standard definition youtube videos take longer to load than those Apple videos... and I doubt they have a local server here.
Nothing is impossible with streaming video, you want the ultimate, it just costs more.
It's not important the problem be solved, only that the blame for the mistake is assigned correctly -
sum_guy did Apple use streaming video? It did look like it was preloaded like any other clip.
It's progressive download "streaming", not RTSP
Huge bandwidth on Apple's end, I'm sure they have worldwide CDN, including Thailand -
It's definitely being streamed. My connection is very fast, but it still buffered before playback. If you have enough server and bandwidth, streaming a 27 mb file isn't that tough. Apple isn't being cheap with it's downstream bandwidth.
Wow poisondeathray that you brought up CDNs made my day! I make money online since several years and run several websites but never looked into CDNs. Quite embarrassing lol. There are actually some that are pretty affordable and from what I read pretty fast too. Thanks!
IMO Amazon cloudfront is a good one, with reasonable prices, worldwide coverage
Good free CDN if anyone is interested...
http://www.coralcdn.org/It's not important the problem be solved, only that the blame for the mistake is assigned correctly -
Coral is a free peer-to-peer content distribution network, comprised of a world-wide network of web proxies and nameservers. It allows a user to run a web site that offers high performance and meets huge demand, all for the price of a $50/month cable modem.
It's free, just append the following to your URL.. .nyud.netIt's not important the problem be solved, only that the blame for the mistake is assigned correctly
New Apple TV rumored to launch with iPad 3
By edDV in forum Portable VideoReplies: 14Last Post: 6th Mar 2012, 12:28 -
Apple Ipad...who's buying one?
By budz in forum Off topicReplies: 24Last Post: 18th Jun 2010, 23:39 -
Encoding for Apple TV
By hkaplan131 in forum ffmpegX general discussionReplies: 13Last Post: 11th Oct 2008, 14:20 -
3GP_Converter (For Apple Devices) Updated: Quad Core Support + CRF Encoding
By GMaq in forum Portable VideoReplies: 1Last Post: 20th Sep 2008, 08:52
thanks for your sharing !
