Good morning. I'm a newbie and need help!!! I've successfully converted an avi movie to mpeg. However, I'm experiencing two issues that I can't figure out:
1. When I convert an avi file (that's let's say 700 mb) to mpeg it increases in size to approximately 1.3 gb. Is this normal. I'd like to keep the original file the same size, if not smaller.
2. I've tried cutting the mpeg to fit onto two disks, but I don't know where in the movie to cut it. I don't see where it gives the option to cut it based upon the file size, but rather on the # of frames. How do you know what # of frames can fit on a standard cdr or cdrw?
I've used tmpgenc to convert and edit the avi -- and nero to copy to disk. I've also read the very good and comprehensive newbie guides on this webpage, but still have questions.
I'd appreciate any tips and suggestions. Thanks.
goto tools on the let hand side under other and get sefy templates for temgenc and use these as they are very good or email me and i will send you some that are very good for what you want
there can only be one:but its not me -
if u want to maintain file size(by means of only using 1 cd) and maintain same quality, email me at locooverrider@hotmail.com we can do vcd or svcd, whatever u wanna do.
And also keep in mind, this is not xvcd or xsvcd either!! This is standard vcd or svcd, VERY compatible.ShiZZZoN PzN
Everyday is another payday and I am one step closer to becoming the one.
Converting and Editing AVCHD
By akosvfr in forum Newbie / General discussionsReplies: 0Last Post: 3rd Aug 2011, 04:08 -
Capturing and Editing/Converting
By eighteesix in forum MacReplies: 3Last Post: 26th Mar 2009, 11:20 -
Converting MTS for editing...
By Saibot in forum Video ConversionReplies: 1Last Post: 18th Feb 2009, 19:57 -
Converting DVD to AVI for editing
By CaptainChaos in forum DVD RippingReplies: 18Last Post: 16th Jul 2008, 10:20 -
Using Blueray or HD , Converting or Editing
By Fary4u in forum Newbie / General discussionsReplies: 1Last Post: 13th May 2007, 16:42
