hi there, i was capturing a video with camstudio when the program seemed to crash. i looked around and found a temp .avi file a little over 4gb in size, and tried to open it. in the properties, it definitely says it is a .avi file and it has the .avi extension, but every program i have tried to use does not recognize it as an .avi. i tried playing in every player including vlc, and i tried a number of .avi splitters, fixers etc., and each one says the same thing basically: "this is not a .avi video" if you have any idea how to fix the file so it is recognized, i would really appreciate the knowledge.
thanks!
Please do not cross post. I deleted your other thread.
yeah, tried it. tried messing with some settings too as i read to do in a post somewhere else. still just says: "the file "c:\....filename.avi" is of an unknown or unsupported file type."
since camstudio crashed, was it maybe saved to the temp folder incorrectly? i tried putting it in notepad just to look (i can't code things) and the file size was too big for that. i also noticed that in the properties, it says it is an avi file and has the .avi extension, but there is no information in the video details (length, frame width, etc.)
i guess i'm just hoping that 4gb of info can somehow be made to be readable, even if i have to learn some basic stuff about headers and whatnot -
VirtualDub reconstructs headers when they're corrupted. I think your AVI is hosed.
Time for an HD cam.. Last cam was Pana. DVC80.. Next will be?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 25th Nov 2011, 18:35 -
Cam Studio now incorporated in Download Helper 4.9 for Firefox 4.0 or later
By mgh in forum Video Streaming DownloadingReplies: 1Last Post: 16th Jun 2011, 22:39 -
How to increase when TC OR CAM DVD to Tc or Cam rip
By antonymaheshca in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 13:42 -
Edit 3 cam's with Pinnacle Studio 12 Yes you can
By Habby in forum Authoring (DVD)Replies: 2Last Post: 26th Jan 2009, 19:28 -
DV -> PC through Firewire: cam not recognized
By MrSplinter in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 8th Aug 2007, 18:11
