I've made the decision to begin editing the movies I made on a Canon A710 years ago for two reasons. One to consolidate multiple clips into a single video in some cases but also to convert the bloated AVI files into MP4 format. I have some experience with doing this but am just looking for additional advice. Essentially the AVI files are at a data rate of ~14.5 MB/s and 88 KB/s audio. I'm not sure why they are so big as the quality is standard 640x480 but nonetheless a 1 minute video is ~110 MB. I will convert these to MP4 using quicktime which is quite simple but was just wondering if anyone had advice on choosing the output data/audio rate. I know ~7MB/s is near DVD quality but these were shot with a A710 so even if I wanted to put them on a DVD later would it matter if they were 14, 7, or 4 MB/s if I was watching it on HDTV anyway? I want to get the best bang for my buck if it is discernable. My intention is to convert at 4.8 MB/s with audio at 128 and essentially that 110 MB file becomes ~35 MB minus any additional footage I clip out.
I'm thinking of my kids here and would like to have a single video file for an event (when there are multiple videos) with all the dead time removed and at a data rate that would not be destructive. Thanks in advance.
	you would do best to find a good encoder that allows you to pick a constant quality setting and set it to highest quality. This will create a variable bitrate file that will probably be smaller than the constant bit-rate you second guessed yourself about until you decided on max just in case.
 I used to be a constant bitrate guy..always setting my dvd's to 9300kbps..only recently have I realized I've been wasting space!
 People have said good things about xvid4psp..it's freeware and can be set to use constant quality.
	Sorry, I'm not sure what this is means in regards to the question.
 greymalkin, that software looks interesting and I appreciate the information. The majority of videos will involve both combining and editing. It looks like that program is very useful for conversion but I am not sure it allows any editing and I don't see a constant quality setting within Quicktime.
	Just remember to always save the original files. Then you can start over should you ever need to with the original quality. Burn them to dvdr and backup on an external harddrive for a safety copy.  Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
  Problems converting MP4 to AVIBy Missmax in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2012, 15:40
  Help converting WMV and MP4 to AVIBy ffabioo in forum Video ConversionReplies: 2Last Post: 18th Dec 2011, 13:51
  Converting mp4 to aviBy socrates in forum Video ConversionReplies: 2Last Post: 2nd Dec 2010, 09:10
  converting .mp4 to aviBy georgeyboy in forum Video ConversionReplies: 3Last Post: 6th Nov 2007, 21:13
  converting mp4 to aviBy georgeyboy in forum Video ConversionReplies: 0Last Post: 6th Nov 2007, 09:03
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
