How can i project 2 videos in sync with each other . i have normal dvd players and the videos need to be projected on 2 different walls and the audio & video on 2 different players should be in sync with each other.
no therea are two different videos being played parallely and they need to be in sync with each other
I am in a serious panic for affordable suggestions as to
how best synchronize DVD players for a multi-channel video installation. I cannot afford to buy industrial dvd players...I have to install this weekend at a gallery and I have just been able to gather all components to view piece as a whole...and I am realizing it is not staying in sync! Unfortunately the piece is completely dependent on that factor it really needs to stay in sync by 1 frame if possible. Help?
One idea is to loop the sequence in fcp for about 1 hour- whatever will fit on a dvd so there will be less stop and start with the disk in the dvd player & maybe that will lessen the possibility of falling out of sync!?
Audio out of synchronization after IVTC
By Anonymous344 in forum Video ConversionReplies: 7Last Post: 28th Sep 2010, 21:54 -
subtitles synchronization
By Grendel007 in forum SubtitleReplies: 1Last Post: 29th May 2010, 23:22 -
Best Cues for Audio Synchronization (Manual)
By uart in forum Newbie / General discussionsReplies: 3Last Post: 18th May 2010, 13:39 -
Audio Codec after Synchronization
By Aurlito in forum Software PlayingReplies: 0Last Post: 13th Mar 2010, 11:47 -
vdub synchronization prob.
By dnan in forum EditingReplies: 6Last Post: 19th Sep 2007, 08:00
