I have just purchased a second hand Pioneer DVR-520H-S Recorder. I normally receive TV via a satellite STB which is connected to a Samsung LCD TV. Input from the dish is via cable to the STB and then Scart cables to the TV.
There is another Scart output on the STB that indicates VCR connectibility (the recorder could connect here I presume). The recorder could then be connected to the TV.
In some diagrams I've seen, there is also a coax (aerial) cable running from the STB to the recorder. Is this necessary?
I understand that the satellite receives digital signals and the STB converts to analogue and that the recorder with it's in-built tuner would not be able to process direct from the satellite.
If I wish to record one channel (receiving via the STB and recording on the Pioneer) and viewing another channel (viewing via the STB to TV), What should be the connection setup?
Anyone any ideas (or diagrams would be best)?
	In my experience, STBs that are not also DVRs can only tune one channel at a time, and all the video outlets provide the same channel. If that is true, without a second satelite receiver you will be limited to watching and recording the same thing.
  Problem connection HDD to TVBy WinSpecToR in forum DVB / IPTVReplies: 8Last Post: 19th Feb 2012, 13:16
  Connection help please! HDD Recorder, SKY TV to TVBy sarahholland in forum DVD & Blu-ray RecordersReplies: 1Last Post: 16th Apr 2011, 07:38
  Copying from standalone hdd recorder's hdd to pc hddBy flez in forum ComputerReplies: 7Last Post: 6th Dec 2010, 07:17
  HDD setup for videoediting too ?By Dash1 in forum Capturing and VCRReplies: 8Last Post: 11th Dec 2007, 11:11
  PC HDD Driver for Panasonic DVD Recorder HDDBy SG-01 in forum DVD & Blu-ray RecordersReplies: 9Last Post: 30th Aug 2007, 04:54
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
