Hi There,
Newbie here so please excuse my lack of knowledge. I/My cricket club have just acquired a new hd Camera( panasonic hdc-sd600). We will be using it for technique video analysis but my problem doesn't solely lie with that. I would like to know the easiest way to share the avchd files on to disc preferably to issue both the players and other coaches a copy? I would ideally like to keep the the hi res format if I can but this isn't essential.
Thanks for looking
Josh
	MultiAVCHD can produce HD AVCHD discs for burning to DVD that can be played in PS3s and some Bluray players. It can also produce BluRay output that is playable in some BluRay players when burned to BD blanks.
 If you want the most widely playable format then you can also output DVD Video format, but it will be in standard definition format.
 Your only other option is to burnt he files as data, but this will only be playable on computer witht he right codecs or player (MPCHD could also be included on the disc for Windows machines)Read my blog here.
	copy the camera files onto disc like any data file. they will be able to play them on their computer just like you do. if they are too big to fit then re-encode them to a smaller size with something like handbrake, xmedia recode, mediacoder, etc. --
	Thanks for quick reply.
 Is multiAVCHD software? Sorry for ingnorance if it is... if so will it out put SD quality onto DVD as you suggest for distributing to other members?
 JB
	Sorry aedipuss,
 Itried that for a colleague but his pc wouldn't play the .MTS files Need it to be simple as unfortunately most of the recipients are even less tech savvy than me.  Better if they can stick it in a dvd player and watch it on tele. Need it to be simple as unfortunately most of the recipients are even less tech savvy than me.  Better if they can stick it in a dvd player and watch it on tele.
 Josh
	Brilliant.
 I am downloading it now and will giv it a crack thanks fopr all the quick responses. I'm sure u will all hear from me soon with my next dilemna.
 Regards
 Josh B
  Output file is way bigger than input file in VirtualdubBy sasuweh in forum Video ConversionReplies: 31Last Post: 10th Oct 2013, 18:25
  How to get output file size before converting a file using ffmpeg?By hayden in forum ProgrammingReplies: 1Last Post: 26th Feb 2012, 08:04
  AVCHD editor Sofware with lossless video output,which can handle PSF formatBy Stears555 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 14th Feb 2012, 04:56
  AVCHD file A/V out of synchBy DVWannaB in forum EditingReplies: 2Last Post: 22nd Sep 2009, 10:05
  DVD output from AVCHD and Vegas Pro?By theaterguy in forum Newbie / General discussionsReplies: 2Last Post: 28th Oct 2008, 03:56
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
