Results 1 to 9 of 9
  1. i got a couple MKVs with h.264 video and DTS audio, i want to mux this into a VOB, the only program i have came across is gotsent, but it seems to convert my DTS into AC3, which i do not want. so... does anyone know a program that will allow me to mux my files into a VOB?
  2. do you mean "psuedo vob" for ps3
    have you tried mkv2vob ? not sure if it converts dts to ac3
  3. Originally Posted by poisondeathray View Post
    i have installed mkv2vob, but can't understand how to use it, i configure my settings and there is no convert or start button, WTF?
  4. you can use xmediarecode which will encode to vob and the keep original audio if you want, it also has many presets for devices xbox ps3 etc...
    Feb 2011
    Canada
    You could try Avi2DVD, this is the program that I use when converting mkv files to dvd format. But, here again, it does not support DTS audio at this time, so you would have to convert the DTS to AC3 (using such as audioconverter in mkvtoolnix) before using the program.
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    You read a guide, http://www.bitburners.com/articles/convert-mkv-files-for-playstation-3-using-mkv2vob/4022/ or use another mkv to mp4/avchd tool https://www.videohelp.com/tools/sections/all-in-one-mkv-to-mp4-avchd-ts .
    xmedia recode and avi2dvd will reconvert to low quality dvd.
    Apr 2004
    Miskatonic U
    The PS3 doesn't seem to be happy with DTS audio in any format other than authored disc structures (AVCHD or DVD Video) played from optical discs. That said, I haven't bothered with the pseudo VOBs, so maybe that will fool it.
    Read my blog here.
    Feb 2011
    Canada
    When you suggest that avi2dvd converts to low quality dvd...by that do you mean converting from higher quality HD mkv or that the program itself does a poor job when converting any mkv (SD or HD) to regular SD dvd? I've used it in the past to convert regular SD mkv's to DVD and it functions well. Why would anyone want to convert a high def file to sd dvd?
  9. Member yoda313's Avatar
    Jun 2004
    The Animus
    So it can be played on a plain vanilla dvd player - while preserving widescreen if it has it and digital surround sound downconverted to sd surround sound of course.
    I have never used avi2dvd but i have used avstodvd to make dvds from high def sources and it does a very good job.
    I believe Baldrick was referring to the fact that the sd dvd will naturally be lower in quality than the original high def source because of the nature of the dvd format itself - not that the program will make an inferior dvd I presume.
