what are mkv files for ?
whats a good software to convert mkv to avi
Mkv is a just another container like avi. It has different capabilities than some containers. I'm not sure what the differences are exactly but it is different than mp4 or avi. But it is still just a container.
the usual suspects:
format factory
super
xvid4pspDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Use gspot or mediainfo to identify the video inside.
If your player (do you mean dvd player?) supports the codec and the resolution its in then you can simply remux the video without reencoding.
You could try winff or avidemux for that.
edit - if its a high def mkv you almost certainly won't be able to play it as high def on a standard definition dvd player. That would need to be fully reencoded to a format it can read in standard defintion resolution.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
They can be useful containers as MKV files can also carry multiple subtitle tracks and audio tracks.
How to convert MKV to AVI or OGM to AVI using mencoder
By Baldrick in forum User guidesReplies: 75Last Post: 17th Dec 2013, 12:19 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
MKV Audio + AVI Video to avi using ffmpeg?
By kwanbis in forum Video ConversionReplies: 9Last Post: 15th Apr 2012, 21:45 -
How to convert matroska MKV to AVI or OGM to AVI
By Baldrick in forum User guidesReplies: 211Last Post: 13th Apr 2012, 01:56 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 03:45
