I made a DVD movie and added a few photos at the end of it. The photos at the end of the movie didn't really look that hot compared to the way they look as a plain photo. They looked somewhat grainy in the movie.
The photos by themselves are 10 mega pixels with a width of 50.667 inches and a height of 38 inches with a resolution of 72 pixels/inch.
What settings should I use on the photo before I import it to the film and make the DVD movie.
Your authoring program will resize them for you, but if you want complete control then you should resize them to DVD compliant resolutions.
PAL 16:9 - 1024 x 576
PAL 4:3 - 720 x 576
NTSC 16:9 - 848 x 480
NTSC 4:3 - 720 x 480
Better yet, if you have a recent version of Photoshop, use the built-in templates for your format (PAL or NTSC) and let Photoshop deal with the non-square pixels issues for you.
Remember though - DVD is low resolution, standard definition - your photos will never look as good encoded as DVD video
(These are 1:1 PAR resolutions. Your authoring tool will resize them fit the 720 x 576 or 720 x 480 video resolutions of DVD - hence the suggestion of using photoshop's templates)Read my blog here.
Your restricted to the max resolution of you chose dvd format ... click "what is > dvd"
You may author a dvd and include another directory such as Picture ...
Dvd contains the following directory structure
Audio_ts
Video_ts
It'll need to be burn using imgburn ... how or if it works on any given home dvd player is unknown ... you can try.
To view the photo's you would use the home dvd players explorer interface as used for navigating data discs ... well mine dose
BJS,
I'm not sure I completely understand you but I'm just including the photos in the movie itself and then increasing the length of time the photo is shown inside the film, then running transitions and psychedelic video effects on those photos. It comes out pretty cool with the music and everything. But yeah, I haven't actually run it on the dvd player yet. But it is included inside the VOB file so I don't see why it wouldn't run.
HD Movie resolution problem
By Penicillin in forum DVB / IPTVReplies: 3Last Post: 21st Jul 2010, 16:18 -
pre click photo movie maker
By motleycool in forum Newbie / General discussionsReplies: 2Last Post: 16th Dec 2008, 01:06 -
Photo DVD slideshow movie
By j4mes_bond25 in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2008, 06:58 -
mpeg video movie - can't grab the photo!!!
By fingerbuster in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jul 2007, 13:43 -
resolution on movie nero digital
By krain_l in forum Newbie / General discussionsReplies: 3Last Post: 25th Jun 2007, 00:49
