I'm brand new to the site. I've been pouring over the guides and love all the information but I can' seem to find information I need. I want to be able to edit my DVD's and keep the original menu. For instance, I have district 9 (great movie), but my kids want to see it. They aren't old enough to handle the mature language and some of violence. I want to be able to edit out that content, but keep the rest of the DVD the same, including the menu. I've looked at a some software such as DVDRemake, Womble, TMPGenc, but it looks like with these you have to create your own menu system. I don't want to do that. Any ideas? I tried searching but I don't know enough of the lingo to make my searches very good.![]()
ditch the menus. the kids don't want or need them anyway. go movie only and edit to your heart's desire. but the kids can probably handle more than you want to think.
I guess that would work, then how would they jump to scenes? It would be like sticking in a VHS tape and having to fast forward to where you want. Is it not possible keep the menu? Thanks for such a quick response.
You're probably gonna get a caution about your thread title.
I suggest you re-title it: Edit DVD and keep menu?
Anyway I agree about the menus. Easiest way would be to re-author with DVDShrink and use the Start/End Frame function to cut out what isn't wanted. DVDShrink will re-map the movie preserving *existing* chapter locations. Here's how:
http://www.mrbass.org/dvdshrink/
That's the general idea, but to make multiple cuts, you need to reauthor multiple instances of the main movie. Like this:
http://www.dvdshrink.info/re-author-advanced.php
Another way is with VobBlanker, harder to learn but a more elegant method certainly. Any guide will do.
If you insist on keeping menus, you can do the above, then add back the original menu with this method:
http://jsoto.posunplugged.com/guides/VobBlanker/adding_menus/index.htm
This is not exactly advanced stuff, but it's a steep challenge for a beginner. But anyway, have a go and see for yourself.
Good luck and welcome to the forum.
Pull! Bang! Darn! -
Thankyou, I will start working on it. Also, I changed my title. Thanks for the heads up.
You donīt need to keep the original menu (unless itīs really important to you)...you rip/convert the main movie, edit with the method of your choice (re-authoring with DVDShrink, using an editing program, etc...) and then load your edited file into an authoring program (there are some free and simple enough to use) where you can make a custom menu, porbably not as flashy as the original one but just as functional, or at least make chapter points so your children can skip back and forward as they please.I guess that would work, then how would they jump to scenes? It would be like sticking in a VHS tape and having to fast forward to where you want. Is it not possible keep the menu?
So far things are going well. I had it mostly done when I realized the captions weren't showing up (from the aliens talking). Now I gota figure out how to get those back on the video.
how do i edit menu connections on an existing dvd?
By animalia in forum DVD RippingReplies: 7Last Post: 14th Jun 2010, 03:42 -
Edit dvd menu button
By canaQ in forum Authoring (DVD)Replies: 8Last Post: 24th Feb 2010, 07:13 -
Can you edit DVD menu without going through long rendering?
By johnharlin in forum Authoring (DVD)Replies: 3Last Post: 23rd Aug 2009, 22:25 -
How can I edit a montion menu of DVD?
By schtroumpfs in forum Authoring (DVD)Replies: 3Last Post: 9th May 2009, 05:57 -
PowerProducer - edit dvd menu template
By kj1983 in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2008, 18:37
