Issue: Sporadic problems rendering HD video files when producing a Blu-ray DVD using Photodex ProShow Producer or Roxio's Creator Pro.
I make Blu-ray DVDs from my own Canon HD Vixia HF S10, and from HD downloads from YouTube that usually are mp4 files. I use both the Photodex and Roxio softwares above in producing projects usually less than an hour long. Frequently there will be a video file or two that will cause a problem, like a freeze in the rendering, or refusing to accept an edit.
Is there anyone out there that has developed a good list of do's and don'ts regarding working with file types? Are there some file types with certain profiles (like a particular video codec, a particular frame rate, etc.) that really have to be converted to something else to work with? And are there some file types that we mortals just should not try to edit or truncate at the start or the end regarding stability?
This moderately experienced amateur would like to see a set of do's and don'ts for working with HD files.
Thanks very much
Chuck Falk
Aiken, SC
Results 1 to 1 of 1
Video files open but don't play
By necrolancer in forum Newbie / General discussionsReplies: 3Last Post: 1st Jun 2010, 01:24 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
bitrate lower than set when VBR rendering in Vegas 8
By gtmb in forum Video ConversionReplies: 2Last Post: 29th Sep 2008, 08:02 -
Having Problems Rendering & Authoring with 1 Video File...!
By tug_hill2 in forum Capturing and VCRReplies: 1Last Post: 20th May 2008, 03:27 -
Subtitles wont/don't display on set top players
By scamuel in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 24th Jan 2008, 08:31
