Hi there, uploaded this video recently to blip.tv: http://blip.tv/file/4825719
Normally I use compressor to make an MPG4 to go up online. However, this video has more detailed graphics and a lot of quick movement as you can see. I uploaded as an MPG2 and tried to remove the interlaced effect. Two questions:
1. Any recommendations on how to remove the interlaced effect when there is quick movement?
2. Does uploading a bigger file effect everyone's playback? If you upload a 150mb file as opposed to a 700mb file. On a website like blip.tv, is the load time greater for the viewer?
blip has the option to play the original file (no quality loss)
mpeg2 isn't compatible with flash, so it has to be re-encoded (quality loss) .
It might use the quicktime viewer if the end user has quicktime and the mpg2 plugin installed (this will be tiny percentage of viewers), otherwise it won't play the original format
uploading a bigger file only affects playback if that identical file is used for streaming and not re-encoded (usually not the case for mpg2)2. Does uploading a bigger file effect everyone's playback? If you upload a 150mb file as opposed to a 700mb file. On a website like blip.tv, is the load time greater for the viewer?
you don't have as many good options on a mac to deinterlace, but you can try jes deinterlacer or mpegstreamclip to deinterlace1. Any recommendations on how to remove the interlaced effect when there is quick movement?
Fixing an MPG4 file
By Linz1607 in forum Video ConversionReplies: 1Last Post: 30th Nov 2010, 11:45 -
MPG4 File Repair
By RickGaspar in forum Newbie / General discussionsReplies: 2Last Post: 6th Jun 2010, 12:14 -
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
Help with brief video freezes in mpg4 avi
By hibbs in forum Newbie / General discussionsReplies: 5Last Post: 28th Apr 2010, 19:04 -
MPG2 or MPG4???
By JennyBear in forum Newbie / General discussionsReplies: 7Last Post: 1st Aug 2007, 18:33
