I am driving myself crazy looking for software that will allow me to do this. let me elaborate;
i want a program that will let me split a video into a bunch of pictures that i can edit , e.g. put other people heads on people in the video, then turn it back into a video that can be watched
any help would be greatly appreciated, thanks in advance.
Change your font mate and relax,
avidemux save> save selection as JPEG images if you have 10000 frames you have 10000 pictures.
when your done ediiting thhe images open either overwrite the edited image or replace with the same name in the folder there all saved to
then open the first in avidemux and it should open all in sequence order 1.2.3.4 then save as mp4, mkv,avi. -
cheers buddy, appreciate it. i wouldn't care that much its just that i've literally been looking for about 2 weeks.
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
POSSIBLE? Captured 8mm Movie Frame by Frame Editing
By PLW in forum Newbie / General discussionsReplies: 15Last Post: 21st Jan 2009, 13:21 -
Editing Text Frame By Frame In After Effects
By sk8_aholic in forum EditingReplies: 4Last Post: 18th Nov 2008, 18:27 -
Frame by Frame Editing / Painting
By abvision in forum EditingReplies: 6Last Post: 2nd May 2008, 11:34 -
Suggest a video editor for frame-by-frame editing
By ontherocks in forum Newbie / General discussionsReplies: 14Last Post: 24th Apr 2008, 09:36
