Can someone tell me of any programs I can use to backup data onto CD and DVD and encrypt
I've searched, but surprisingly can't find anything
Would like open source
But happy to pay if there are no good free ones
OM
TrueCrypt http://www.truecrypt.org/, free and opensource: Create a file hosted volume and burn it unto CD, like you burn a normal file. Will work just fine.
so i can specify a specific folder to be encrypted?
please confirm
it's something i considered before - but thought it meant encrypting ur whole drive?
looking at the program again now though - EDIT: i've looked at again and it doesn't say anywhere that u can encrypt a folder and everything under it - or at leas it doesn't explicitly say this - so let me know if u know otherwise
thanks -
Truecrypt creates password encrypted containers to host a file like a video or document inside it like a mkv holds h.264 video,
so you can select any type of file but the disk can only be played back on a computer not a standalone dvdplayer.
The computer that creates the encrypted disk needs truecrypt while if you open the disk on any other computer you only need the password.
<You Need Truecrypt on your computer - Your Friends computer doesn't need truecrypt to decode, it only needs the password.
Heres a quick guide: http://www.ghacks.net/2009/08/10/how-to-password-protect-data-on-cds-or-dvds/
DVD "Unreadable" - Can I backup data on my comp?
By TechFool83 in forum ComputerReplies: 24Last Post: 24th Dec 2011, 12:22 -
Can't see data on a DVD-RW ! Please help!
By Icaro in forum MediaReplies: 10Last Post: 20th Jan 2011, 05:45 -
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 09:00 -
Data Backup Software
By AuroEdge in forum ComputerReplies: 0Last Post: 26th Sep 2008, 20:48 -
Can anyone suggest a GOOD app to backup my computer data?
By Hittz in forum ComputerReplies: 14Last Post: 4th Jul 2007, 14:37
