Found a post with a guy having the same problem as me but could not find an answer so here is an exact copy of the problem. Any help would really help guys.
ive used this program for years. great program.
i just purchased a new computer running the 64 bit windows 7. ive installed the program normally and the first project i did. everything worked fine.
but for some reason when i went to do up another project. now no matter what i do it wont let me add assests to the project.
the assest is an AVI. its currently installed into the C:\ only instead in the programs folder. i gave it admin running rights also.
tried reinstalling a few times etc etc. i dont know what changed since the first project i did on the new computer. it worked fine the first go around, but like i said: now it wont let me add assests. i click to add, the file browse window closes normally. but nothing ever appears in the bottom where the assest titles show when added etc. so i can process or anything and finish the project. any ideas?
Ok, as you just copied and pasted the other post I need to ask:
Did you install to a location other than 'Program Files'?
Are you runnung the program as administrator?
Have you tried Drag and Drop to add files from Windows Explorer (Computer)?
What is the file type and path to the file?Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
svcd2dvd ffmpeg has stopped working adding dvr-ms
By Pooch917 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 1st Mar 2010, 09:00 -
Windows 7 Ultimate - Can't load assets in SVCD2DVD
By ttyner in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 13th Jan 2010, 10:54 -
Adding subtitles to an SVCD2DVD project :shock:
By bxmbxm in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Aug 2009, 10:54 -
Problems using SVCD2DVD converted assets in DVDLab
By techboy_66 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 18th Apr 2008, 16:28 -
Assets problem
By tandaman in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 7th Jul 2007, 18:25
