Can somebody tell me the best settings for Xvid codec in Virtualdub 1.9.10 (for single pass) such as "Profile level","Zone options","other options","quality preset" etc. because i want to embeded subtitles (srt filter) in avi files.
I put the same bitrate but the result is less quality than the original. Much less actually
Thanks in advanced.
but then the file size is increased. Am i right?
We are talking for 624*352 in 990 Kbps at 23.976 -
yes file size should be increased with q=1
if you re-encode using xvid (or any lossy format), you will always reduce quality . You reduce that quality loss by using higher bitrates (lower quantizers)
start from the original source DVD / blu-ray if you want better quality -
Then you have to make some trade offs - either suffer the quality loss with same filesize or increase the filesize with less quality reduction
Or use better compression than xvid (e.g. x264 encoder)
Or use softsubs and no quality loss -
Soft subs means keeping the subs external to the video and having them play along. Most standalone MPEG-4 players support external subs in some formats so check your manual to see which formats are supported. Usually SRTs are supported, and sometimes others. If you can do it that way it'll save you from having to reencode the AVI. Just make sure the subs have the same name as the video (like Movie.srt and Movie.avi). Then burn them to disc together, the AVI and the subs.
Different players have different ways of 'turning on' the subs. You might try using the Subtitle button on the remote control. Again, check your manual.
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 13:35 -
XVid codec settings question?
By 3thman in forum Video ConversionReplies: 5Last Post: 10th Oct 2009, 16:36 -
Xvid Codec settings (1.2.2)
By glenpinn in forum Video ConversionReplies: 2Last Post: 21st Jun 2009, 10:29 -
Intermediate codec and xvid question, and xvid to wmv.
By ^xRun^ in forum Video ConversionReplies: 9Last Post: 22nd Jul 2008, 17:13 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 11:47
