Hello
I have a movie that is 81min long and i want to fit it on one CD in SVCD format, with out loosing so much of the qualitet. Wath bitrate and stuff should i use in TMPGEnc?
Or should i use Sefys SxVCD,SeVCD to do this.
THX
USiT
Hi,
More than one possibilities here.
1. Dump the ending credits using TMPGenc.
2. Burn to a 90min/800 MB disc.
3. Overburn on a good 80min disc. (TDK, Verbatim etc..)
4. Reencode something at a lower bitrate (this will create a non compliant vcd!!! called XVCD)
About point 4, the fastest way would be (Since you're creating a XVCD) to reencode the audio at 192 or even 160 Kbps MP2. Then demux the video from your current mpeg and re-mux it with the new audio file in TMPGenc.
Greetz,
pSyChO dAdThe difference between genius and insanity is only measured by success ! -
I agree with Psycho_Dad_Rules, no reason to use any specific template for your movie, it's just 81min, any good quality CDR can do overburn to that capacity without a problem, you can maximum reduce the audio from 224k to 192k and it will fit smoothly and you don't lose Video Quality and audio quality is still very high.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Can I fit 5.3 GB video on a 4.7 GB DVD?
By better life in forum Authoring (DVD)Replies: 13Last Post: 16th Nov 2008, 20:42 -
fit 3 movies to dvd5
By thecrock in forum Newbie / General discussionsReplies: 9Last Post: 19th Jul 2008, 14:00 -
auto fit
By roystheboy in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Jun 2008, 05:23 -
How many can I fit on a DVD?
By love2learn in forum Newbie / General discussionsReplies: 1Last Post: 17th Nov 2007, 11:46 -
Help to fit two DVDs into 1
By heretic1 in forum Authoring (DVD)Replies: 1Last Post: 12th Jun 2007, 22:57
