I have a large .mkv file (13GB). I want to convert it to AVCHD and burn it to disc to play on the PS3. However, I want to spread it over 3 x 4.7GB DVD's.
I used TSMuxer and set it to split the files. I then went to burn to disc using imgburn. The thing is, TSMuxer only creates one CERTIFICATE and BDMV folder with the split files inside. When I try to use imgburn it obviously says the file is too big to burn to the disc.
So how can I split the file to create 3 each of CERTIFICATE/BDMV? I noticed popBD does this but will only create 2 AVCHD folders for burning?
Can anyone help?
Thanks.
Sorry, I don't understand?
TSMuxer creates just one BDMV folder and one CERTIFICATE folder...I don't create them myself? The file I have is just one 13GB file...so how can I load one file at a time into TSMuxer when it is just one file? What is TS?
I've just tried using multiAVCHD and this has split the file. However, I now have the following:
Folder: AVCHD_FOLDER_SPLIT containing VOL_001/2/3 and 4. Each one of these has a BDMV folder in it. But there are no CERTIFICATE folders to be seen? So how do I now burn these 'spilt' files to disc with imgburn?Last edited by leamingtonspaceman; 5th Mar 2011 at 17:05.
Finally got this to work. Just burnt the BDMV folders to DVD-R's and they worked
Multiple questions on best file format & quality, conversion from AVCHD
By Scanderoon in forum Newbie / General discussionsReplies: 12Last Post: 2nd Sep 2011, 01:37 -
Possible to burn AVCHD to multiple discs?
By hiimbored in forum Authoring (Blu-ray)Replies: 4Last Post: 2nd Jan 2011, 17:55 -
Help Please- multiple AVCHD to DVD
By Lilygrace in forum Newbie / General discussionsReplies: 10Last Post: 21st Sep 2010, 07:44 -
How to backup multiple AVCHD files to BD-format DVDr without reencoding
By jodal in forum Authoring (Blu-ray)Replies: 1Last Post: 10th Dec 2008, 15:45 -
Multiple AVCHD's to Single Blu-ray for PS3
By hhel11 in forum Authoring (Blu-ray)Replies: 3Last Post: 15th Jul 2008, 13:29
