I want to convert my audio files from 192kbps to 320kbps using an audio editor.My question is will it really improve the quality of the clips or just the size.Coz in video files when you convert a low bitrate file to high you get nothing but added burden.
I am new into this world.You must have got that through my question.
People just do anything with softwares, audio video encoding decoding whatever. I just go baffled.Do they even study?
A simple yes/no to the question will do.But I will be more satisfied if you will enlighten me with more of your knowledge.
Thanks![]()
changing audio bitrate with ffmpeg
By wallywalters in forum Video ConversionReplies: 4Last Post: 11th Feb 2011, 05:45 -
Changing VOB file audio track order
By mmdmmd in forum EditingReplies: 1Last Post: 4th Oct 2009, 16:12 -
Advice on how to downgrade the audio bitrate of a MOV file with AC-3 audio.
By InsanelyOne in forum MacReplies: 15Last Post: 13th May 2008, 23:40 -
Changing AC-3 Bitrate
By kotton in forum AudioReplies: 5Last Post: 1st Sep 2007, 23:29 -
By kotton in forum Video ConversionReplies: 2Last Post: 1st Sep 2007, 22:05
