  1. THE REASON WHY I CAN'T BURN SOME OF MY VIDEOS IS BECAUSE THEY ARE NOT FORMATTED OR ENCODED OR WHATEVER WITH MPEG. IS THERE A WAY THAT I CAN SWITCH THE VIDEOS TO MPEG SO THAT I CAN BURN IT? NEED MAJOR HELP PLEASE!!!
    Feb 2001
    Kalmar, Sweden
    TO GET HELP FASTER DON'T USE CAPS!
    Ok, when that's sorted...
    What kind of input have you got..? Is it a AVI file , ASF or another MPEG..?
    You need to encode your files into MPEG.
    A tip is to use TMPG Encoder...
    Look at your left, under "HOW TO" and look at "CONVERT".
    The answer to your question lies here...
    After that you can look at "AUTHOR" and you'll learn how to burn correctly.
    Magnus Jensen
    A.K.A Geezus
