Results 1 to 23 of 23
  1. I'll try to keep it tight and information packed.
    What I do: I record gameplay content with FRAPS (Uncompressed - so the video files are massive), and my own audio commentary using Audacity. All quality is at 1920x1080 native resolution aka 1080p. I take both the avi from FRAPS and MP3 from Audacity into Sony Vegas and render them at lossless quality. I then use MeGUI to encode them using the x264 Codec. I upload the multiplexed result (merged video and audio) to YouTube as a "Let's Play". The aim is to provide good audio and great picture quality at all quality levels. I nailed the quality and the size (250MB to 500MB for 13 to 15minute videos) at very good picture quality and clear audio.
    The problem I have: The process of doing all this feels very long and ineffective. To give you realistic values:
    • 2 hours of game footage and audio with FRAPS (great quality which I plan on sticking to) turn out to be 250GB of data (I work in a 1.5TB parition, about 1TB is allocated to this Let's Play activity of mine).
    • Rendering this in lossless quality (adds my commentary from Audacity to it) using Lagarith Lossless Codec and retaining perfect 1080p quality raises this to about 275GB of data. (For some reason the Lagarith Lossless Configuration doesn't save the values I set it to be as, it always comes up untouched...)
    • Encoding the above through MeGUI using the x264 preserves the great quality and crisp, clear audio but shrinks the size to no more than 4GB total (huge difference from 275Gig to 4Gig...).
    • All in all, for 2 hours of gameplay I have:
      • 250Gig of raw video game footage + 1Gig of Audio Commentary.
      • + 275Gig of the Lagarith rendered footage
      • + 4 Gig of the Encoded Files (Audio and Video Apart)
      • + 4 Gig of the Multiplexed Videos (Audio and Video gets merged together) which is the final product that gets uploaded to YouTube. An example is the following: >Click<
    What I'd like: Is to find some way to hopefully either skip a few of these steps, and go directly from Sony Vegas to the final Multiplexed Video (I use Sony Vegas Pro 10 btw) or to at least automate as much of this as is possible (for those of you familiar with Sony Vegas and MeGUI). Having to render each loop region individually and perform several tasks for each and every single video part is taxing my time quite a good bit!
    I'd appreciate any and all suggestions. And as a final note, the two points I just don't want to negotiate are the final quality for the size I get (Unless they're both better or the give-take deal makes sense). The video files are in a Matroska format (MKV) and the average size is at 400MB (depending on how abruptly and often the picture changes). As such I'm assuming that the x264 Codec is amongst the best, but I can't figure out how to use it directly from Sony Vegas Pro 10. If I did, I'd be able to completely skip the 275Gig Lagarith Lossless rendering, as well as a ton of time and computer resources!)
    Lupo =]
  2. vegas => debugmode frameserver => megui
    debugmode will eliminate the need for large intermediate export file out of vegas . It makes a "dummy AVI", a signpost that is a few kb big, that the other application (in this case megui) can "see"
    note that if you do multipass encodes, it still might be faster using a lossless render like lagarith. It will depend because effects etc... within vegas will have to be rendered twice instead of once. So if you are doing heavy filtering, it still might make sense to use a digital intermediate
    debugmode only works in 8-bit mode (32-bit not compatible with vegas)
    other option is to use x264vfw , which you can access directly in vegas .
    http://sourceforge.net/projects/x264vfw/
  3. Originally Posted by poisondeathray View Post
    Thank you very much for the reply!
    Will the first option be unusable since I'm on Windows 7 64 bit, using Sony Vegas P10 64 bit or not?
    Having launched the FrameServer it directed me to chosing where this AVI thingy is stored as well as indicate a Source IP and Port value. I'm unsure if I should be entering default values or not. Tried 127.0.0.1, 10.0.0.1 and my LAN address: 192.168.1.64 - It gave me the same "Unable to Connect to Source Machine, Please Check the Source Machine's Address and Port; Also check if the Source Machine has the FrameServer running". I didn't launch any frame server, and am completely clueless as to how I'd use this program.
    Not 100% sure on what it does either, but I think I got the gist of it so if I can get it to work everything would be revealed. But once again, 64 Bit OS and Sony Vegas client for me, having my doubts if this thing would work at all.
    Appreciate a bit more advice on the x264vfw if the above can't work for me.
    Lupo
    That was one hell of a swift reply, btw - I'm amazed!
  4. There are 64bit versions, but they are not completely stable or tested. You can experiment if you want
    Here is a guide , you can scroll down to the 64-bit section
    http://www.bubblevision.com/underwater-video/Vegas-YouTube-Vimeo.htm
    x264vfw is a video-for-windows version of x264cli , you install it and it will show up in any application that uses vfw, including vdub, vegas etc... obviously you need a 64-bit version if you are using 64-bit vegas. You can find a link below for komisar's version
    There is another gui that some other people like more (the options are laid out instead of presets), you can experiment if you want
    http://komisar.gin.by/
  5. Originally Posted by poisondeathray View Post
    Thanks for the reference links - I'm going to go over each and every one of them. Now to keep track of what I'm adding to avoid creating a lot of useless clutter. Once I am comfortable and sink in with what I go anything extra I'll remove. I'll most probably pop back in to request some assistance, because I get lost easily >.<
    Lupo
    P.S. You're awesome!
  6. I've been reading about and around, and honestly I'm overwhelmed. I just started out on all of this, and I plan on taking in as much as is possible, as fast as is possible. The link provided, http://www.bubblevision.com/underwater-video/Vegas-YouTube-Vimeo.htm - I've read through it, or rather - am reading through it and trying to follow along.
    I have a few questions with which I'd appreciate assistance:
    1. My FRAPS recordings are not interlaced (progressive - analyzed by MeGUI a couple of times) and they need no resizing since I record at 1920x1080 natively, since that's the size of my monitor - Would I still require AviSynth script?
    2. During installation of the FrameServer, the author stated it's a bit annoying and creation of files are necessary even for 32 bit OS. My Sony Vegas wasn't installed on the default partition (It's at "E:\Tools\Sony Vegas Pro 10\"), I'm not sure what I should do to correctly integrate this software with Sony Vegas, I'm honestly unable to decipher what he meant by creation that file.
    3. My MeGUI installed is x86 and was a simple extraction of the files to "E:\Tools\MeGUI" (I specified the destination, of course). Is this fine? I didn't find an x86-64 version on Source Forge so I'm assuming the x86 is the one I'll have to be pleased with.
    4. When I installed MeGUI, I didn't import any presets, and the guide recommends to import at least a select few of these, what should I do?
    5. The guide mentions the whole "Create as many Workers as you have cores". I have a quad core (i7 950 @ 3.2Ghz when under load). I've noticed that during encoding, my CPU can occasionally hit 100% CPU usage, and I didn't mess with any worker setup things. Is there some sort of explanation for this? Or is the idea of setting multiple workers just so you can do multiple jobs at once, even though they'll all take quite long to complete, since they're limited to 1 worker only? Appreciate a bit more detail about this.
    6. This is a problem I'm having which is unrelated to the guide and I'd like some information about it: Lagarith Lossless Codec. I've attached two images once "Expected" which is what I set in the configuration option, and another one "Given" which is what I always get when I reopen it, even after setting them. I'm very positive the settings aren't being forced through - but to be honest I'm not sure what they do in the first place. I'm simply following a video I acquired from YouTube which has thus far served me well, even though it isn't being followed to the letter, considering not everything happens the way it should. Is this a 64bit problem? Sony Vegas 10 issue? I just know the video maker was on Windows 7, not sure if it was x86 or x86-64.
    I apologize for the massive requests on all those points, but being very lost at this, unless I am able to answer those throbbing questions, I don't think I'll be able to move on to the next step with video editing X.X
    Lupo
    Thanks for your support.
Name:	LAGS ProblemExpected.png
Name:	LAGS ProblemGiven.png
  7. Originally Posted by Luponius View Post
    No , but megui uses avisynth in the backend. If you use x264.exe, then you don't need avs script. If you don't know how to create scripts, megui will create a script for you
    Not sure how to do it with 64-bit vegas , you'll have to figure it out by playing with different paths
    Thats fine
    You can use them if you want. You don't have to , you can use whatever custom settings you want
    No , threads = cores * 1.5 by default, so you should have 12 threads (8 HT * 1.5 = 12) by default . This works fine. I don't necessarily agree with the info in that link, I mainly posted it to show you the screenshots for setting up debugmode. 1 worker is fine
    Vegas works in RGB, so when you export lagarith it will be RGB. If you force YV12 conversion in lagarith, it will use Rec601 (these are the wrong color coefficients for HD material, you should be using Rec709)
    RGB file size will be a lot larger than YV12 (RGB is 4:4:4 unsampled , YV12 is subsampled 4:2:0)
    By exporting RGB, you can then specify the proper matrix in avs script e.g
    AVISource("lagarithexport.avi)
    ConvertToYV12(matrix="rec709")
    If you don't care about the shift in color , then go ahead and export YV12. If it's not working, it might be a lagarith issue (there was a new version listed today). I never export YV12 from NLE's, always RGB and do the conversion in avisynth
    Another lossless option is ut video codec. It has 64-bit and 32-bit versions. It's multithreading is way faster. Easily the fastest lossless codec. Even your encodes will be faster (because lagarith decoding is often a bottleneck, especially with recent x264 versions which have a threaded lookahead)
  8. I've kept on trying to figure out how to get DebugMode FrameServer to run, but to no avail - it's been several hours now and I'm extremely tired. I've also checked out this video: http://www.youtube.com/watch?v=UyzlXnXoNrs user is "DMFSDemo" so I'm assuming that's the DMFS authors themselves showcasing how to use it.
    It seems a few clicks and a ton of "Next" is all they needed on their system to get it up and running. I ain't as lucky though, seemingly - and I ain't too sure I even have the right, the executable I have is "FrameServer Network Client". The one demonstrated in the video is way different. It was uploaded a few months ago, so it should be quite relevant and up to date. What I downloaded was the latest from http://code.google.com/p/frame-server/downloads/list
    This is the first time I'm hearing about "color coefficients" and the like. It's probably way too much to take in right now. I'm trying to, at least for the time being, get that silly DMFS up and running, although any interesting and informative reading material would be nice - it takes lower priority
    I care about good quality and tiny, tiny size. I tested out the UT Codec (UT Video Codec RGB (ULRG) x64) with "Predict Median" and "Frame Divide Count" of 8 and noticed similar rendering speed (was only a tiny part, so it's probably not a realistic result) and a massive difference in file size. Lagarith (16s video): 236MB. UT (16s video): 456MB. Would this result in a bigger file size, when processed by an x264 or will it not matter anyways - and I should rather aim for the increase in rendering speed of UT?
    Lupo
  9. Well there is no offical 64-bit support for debugmode, so you're on shaky territory there
    There will be no difference in end file size (encoded by x264 using same settings) if you use lagarith vs. UT . They are both lossless if you use the same colorspace
    Are you measuring x264 encoding or rendering speed out of vegas? Vegas is very slow and it might be the bottleneck. I'm talking about rendering in other applications. It's going to depend on the specific scenario, filters used etc.., but I find the render times are significantly faster with UT when using x264. If there are other bottleneck in your setup your results may vary. I personally don't care about temp HDD space, they are dirt cheap these days ,but of course your requirements might be different
    UT is very fast with low decoding latency. It's about 5-10x faster than lagarith. It's even faster than huffyuv-mt. It's more useful for lossless editing (like importing into vegas or premiere). It's impossible to use lagarith for editing scenarios because the latency is too high. Scrubbing is too slow
    If you meant tiny intermediate file size, then FFV1 offers even higher compression than lagarith in YV12 about 1-2%, but it's even slower than lagarith
  10. So I decided to rewrite this post because way too much changed, and all those edits (3 of 'em + this one) were really getting out of hand.
    I got DMFS working (I originally installed it in the Shared Plugins, as opposed to the proper Sony Vegas directory for the IO plugins) and didn't need to mod any files or do anything special.
    I had trouble with it crashing at the start which was fixed by going into File -> Properties -> Audio and turned it to 16 bit, down from 24, and a sample rate of 48kHz down from 96kHz. "Render As..." and launched it in, the feed was up and running. The video sampling was working pretty good (I'll provide statistics to compare DMFS with UT Video Codec soonish) but the audio sampling wasn't doing anything at all.
    I decided to tick "Write Audio as PCM samples in signpost AVI" and the audio was working too. I finished a full render of a single 15 minute region and I'm currently working on the same exact region, instead of rendering it with DMFS, I'm giving the UT Video Codec a shot, which will then, obviously be encoded with MeGUI using the x264 codec. Same region being rendered, same configurations being used, same programs being run on the system (Activated Turbo mode through TuneUp Utilities 2011 which numbs out several minor processes running.
    Once I'm done presenting the data in a neat format I'll post it here as an edit or as a reply, for the heck of it. What I can say is that DMFS is looking like a clear winner in the race of time, ease of use AND (obviously) Drive Disk Space used!
    Lupo
    Bottom Line... Holy shit poison... mate, you're the man!
  11. LOL I didn't do anything . I've never used the 64-bit version of debugmode
    That would be great if you could create a mini guide for other users that want to use the 64-bit version , even post a link on the debugmode forum
    BTW - There's still another option - the vfw version of x264 integrates directly with vegas as well. You're not limited to AVI exports with komisar's version (rawavc, mkv, mp4 wrappers are possible)
  12. Originally Posted by poisondeathray View Post
    Another individual is using that method at this moment, and is considering shifting to this DMFS method having pointed it out. I'll add a little Installation Procedure for DMFS. Should I post it in this thread (maybe first post) or start a new one titled as such in some other, more-relevant board?
    Thanks for your assistance and recommendations, I'm loving the fact both rendering and encoding happen faster than just encoding with DMFS as opposed to UT Video codec!
    Lupo
  13. It's up to you, but if you post it here, change the thread title name, otherwise users using search terms like "debugmode" or "x64" etc... won't find it very easily
  14. I've decided to post it in the Guide Forum and hopefully did a decent job at it. The link to it: ClickMe
    You can close this topic if that's the procedure, my issue was most definitely solved and I'm one hell of a happy man :P
  15. I wrote that guide and have just found this thread.
    Yes, you still need an AviSynth script to convert RGB24 to YV12 and because MeGUI needs an .avs file to read. Personally I prefer to upload 720p to YouTube. They throw away all the even lines of 1080p, however if your monitor is actually 1920x1200 and you record and upload that then they will not throw away half the lines (see here). The other factor is that, for the time being, most computers and internet connections have an easier time playing 720p then 1080p or more.
    I have updated the section of my guide that deals with Frameserver installation, complete with a screenshot, to make it clearer exactly what I personally had to do to get it working on my all-32-bit XP system. I understand a new official version with 64-bit support is soon(?) to be released (there are unofficial 64-bit versions around), so that might cure these troubles. I also provided new links to your guide and to the DMFSdemo YouTube channel. Thanks for those. By the way none of the imageshack pics are showing up in your guide (for me). I posted on the feedback forum to ask the mods to register videohelp.com with them so that they should appear again.
    No need to import any presets. I updated the guide in that respect a few days ago.
    There appears to be no benefit to creating more than worker for the workflow presented in the guide as MeGUI is working in serial fashion, so I have removed that recommendation too. As poisondeathray says, 1 worker is fine.
    Poisondeathray, you are everywhere ... I appreciate your feedback that helps me refine my guide. Thanks for the link to komisar's x264vfw build that can output mp4 and mkv. I'll check it out. It may be great for times when you want to keep everything within Vegas.
  16. Originally Posted by poisondeathray View Post
    I can't find a way to get it to output mp4 directly from Vegas. The codec has to be chosen under "Video for Windows (*.avi)" and output gets muxed by Vegas as .avi even if I put --muxer mp4 in the x264vfw "Extra options:" field and specify a .mp4 filename so it looks like I would have to remux with Avidemux etc.. Can VirtualDub output mp4 with it directly?
  17. Originally Posted by Bubblevision View Post
    you need to specify the directory path and filename in the extra commandline options box
    e.g.
    -o E:\outputfile.mp4
    It will also produce a "dummy" avi along with the mp4 . Supported options are rawavc/avi/mkv/flv/mp4
    But depending on how you have vegas set up , and you import file characteristics, you might not want to use it or have to adjust your workflow (because you don't have control over the RGB=>YV12 conversion like you do when exporting RGB or frameserving RGB out)
  18. Oh, OK. Got that working now. Can't seem to get it to mux any audio in though, and the choice of codecs under the "Video for Windows" list is pretty poor anyway. No aac for example. I think I'm going to pass on this one, but it was interesting diversion.
  19. Thanks for the reply, I have been quite successful with DMFS over the past week or so, in fact the videos in this playlist, from 13 onwards have been done with DMFS. It all happens about twice as fast than the older method and thanks to the improved conversion (appending matrix="PC.709" in the script) I've been able to correct my color quality as well, avoiding as much color loss.
    Overall I'm very happy with the results, the only thing I'd want to improve would be to somehow make DMFS provide multiple feeds, one for each region. Since right now I have to manually highlight each region and serve it through DMFS, create the script and let MeGUI complete the job. And then select another region, so on and so forth. I wish I could just have DMFS smartly change regions to be fed to MeGUI by allowing me to setup several signpost AVI files at once.
    There probably is a way, but it's not something I have so far found nothing that details any such thing.
    Lupo
  20. You can open more than one instance of Vegas Pro and frameserve from them independently. Give each signpost file a different name and create multiple AviSynth scripts with different AviSource names. Then you can just queue up the jobs in MeGUI. I haven't tried it but it sounds plausible. If you try it, please let us know if it works.
  21. If it does indeed allow me to open the same project multiple times with multiple instances it would be the solution to the problem :O
    I'll first have to edit this next 4 hours session, add commentary and whatnot. I'll be giving it a shot after that =]
    EDIT: Sampled two sections from my content and put them both up, ran a script for both of them and even though when trying to sample the second Sony Instance it crashed on me, having relaunched it, it worked just fine without much problems. MeGUI was able to take both at once, but I'm assuming there would be some level of problem with having multiple instance open, even though this is all speculation:
    For one thing, even though processing power is not required considered DMFS only samples what's being requested by MeGUI, I'm assuming that Sony Vegas will put some level of strain on the RAM, unless it can be configured to solve the problem? Especially considering the footage I have is about 530GB (give or take), even though only a fraction of it is loaded into the RAM, this might overall impact my system negatively. Whether this leads to instability and a high frequency to crashes or not is something I can't quite prove right now since I only did a quick dummy attempt!
    It's most definitely going to be fairly hectic to launch ... say, 10 instances of Sony Vegas to feed each of the 10 slots. I just wish DMFS would natively support multiple sections to be fed, or allow DMFS to be run multiple times in the same instance of Sony Vegas, even though that would most definitely conflict with a lot of things, mainly the fact that Sony Vegas only really renders one feed at a time. Hmm =/
  22. Yeah, it's a complex way of doing things and will likely lead to instability. It sounds like you might have more success rendering one big AVC file and then splitting it losslessly into sections afterwards. What you need is a tool that can split the file with "smart rendering" (= no recompression). I don't know what the best tool for that would be, so I'll throw a bunch of words at you that might be way off the mark or might give you a clue: mp4box, Yamb (= mp4box GUI), mkvtools, Videoredo, Boilsoft, TMPGEnc. Some of those ain't free. I bet poisondeathray knows more.
  23. Originally Posted by Bubblevision View Post
    If rendering one big AVC file means somehow re-rendering 550GB of data into another 600GB of Data and waiting on it to finish, that's going to prove very troublesome due to HDD limitations. It would greatly limit me, and the positive points of DMFS, which have so far greatly pleased me would all go. The fact I can run multiple instances is still something I actually don't mind at all, this means I can produce more work while I'm asleep. And yes, crashing or lockup problems would most definitely screw me up and put me back quite a bit, but I'll have to experience that myself with my own system to know for sure - it's most probably worth giving it a shot (multiple SV instances, that is).
    Thanks,
    Lupo
