Hi!
Yesterday I wanted to append two video clips together with VD. But instead, it told me that both files have deferring audio compression rates. So I loaded one of the file, to convert it to others' compression rate. Here's what I tried.
Loaded the file and on video tab choose Direct stream copy.
In Audio tab selected Full Processing then choose the Lame MP3 in Compression and later in Conversion selected one of the given rates as selecting Custom was not working when I typed in the Compression rate/kbps of the other file.
After that I Selected Save as AVI.
Now VD tells me that it cannot find any Audio decompressor to decompress source audio.
I even tried to select Full Processing in the Audio tab and extract the WAV file but same report appears.
But I know that I had extracted VBR audio from files to WAV before but now it was not working.
I need Help in figuring out what is the other cause as I have Lame ACM, AC3ACM installed in plugins .
Thanks for your patience
T.C. & Bye.
			Closed Thread
	s_joy09, Do not post the same topic on several forums.
 Please do not cross post, once is enough.
 Continue in: https://forum.videohelp.com/threads/332553-Virtual-Dub-say-s-No-audio-decompressor-to-d...02#post2062002
 Moderator redwudz
  Trying to encode a clip to XviD to join another using VirtualDub ...By Phat J in forum EditingReplies: 21Last Post: 5th Jun 2012, 03:08
  Virtual dubBy santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 14:48
  help with virtual dubBy Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 16:36
  How do I dub over the audio on a video clip?By SpeedKills07 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Jul 2007, 07:19
  I can't join two avi files with Virtual DubBy Hopalong Cassidy in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 17:21
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
