I've captured a ton of video using FCE. The clips are in MOV containers. However, I want to edit the video in Kino (Linux), which requires AVI. It is imperative that I keep the date/time metadata intact.
One option would be to recapture all the video with Kino, or with iMovie, or DVGrab, but since I already have 1.5 TB of files, separated out into a couple thousand MOV clips, I'd rather not go through it all again.
So how can I batch convert these files into a AVI containers, still in the original DV format, with the metadata intact? A free solution would be preferred, since this is a one-off project.
Thanks!
Results 1 to 11 of 11
No, no. Don't re-encode, just transmux. MPEGStreamclip or QTPro. Not sure about batch - maybe Handbrake.
Scott -
No, I don't want to transcode; I just want to (effectively) strip the MOV wrapper off the dv file. I don't see a way to do that in Slipstream; it seems to only transcode, even if saving as DV. I see no option to just strip off (or change) the wrapper.
I don't have QT Pro.
I'll look into Handbrake. Thanks. -
Not thoroughly tested, though. My apps open the output file fine, but I can't be sure about your app.Code:
ffmpeg -i dvvideo.mov -vcodec copy -vtag dvsd -acodec copy -f avi -aspect 16:9 -y dvvideo.avi
Thanks, Case; I'll give it a try. Why do I need the -aspect parameter? And since my stuff is older 4:3, would I specify that?
Maybe it isn't needed. I saw some example commands that have the parameter, and thought it was a good idea to specify it, as it is just one of those things that can go missing after a conversion or container change - it is just a flag after all. I would specify 4:3 if applicable, to be sure the setting is set. You never know what some app defaults to (ffmpeg or Kino).
depends on your ffmpeg version
usually you do not need to specify it (the parameter is computed from source)
…but sometimes you have to force it
Last, .avi does not handle aspect flag (avi is an old wrapper, it only accept "square pixels", so rescale your file to "square pixels" first, if you want to have a correct display everywhere)
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam. -
No, no, no.
DO NOT scale your file. Transmux it (aka Re-wrap it from one container to the other), otherwise you're losing much quality. By transmuxing, you don't lose ANY quality.
That business about AVI not understanding AR is a red herring. If you're using DV codec (which you said you were), the DV codec itself contains an AR flag, that any self-respecting player or editor can recognize.
I'm not kidding - get QT pro! ($20)
Open your DV-MOV, "Save-As" (or Export, can't remember right now) AVI (w/ DV codec). It has a flag that you tell it "lossless transcode" or something like that (sorry, I'm not at my video workstation today). That's it.
Should only take a moment to export, but knowing QT, it'll take a little longer. But certainly not something like a normal encode.
Scott -
Well, this is getting worse. Computer video is such a nightmare.
I captured all my clips from my Sony TRV720 D8 camcorder, via Final Cut Express, onto my Mac. I want to edit the clips in Linux (it's a dual-boot Mac) using Kino, since that is apparently the only editor on God's green earth that will let me burn the date and/or time metadata onto my video. (Don't editor designers ever wonder *why* that data is there?) The latest version of Ubuntu and Kino have solved the problem of importing my original MOV files, so I thought I wouldn't need to convert them to AVI. Apparently, my 9.04 Ubuntu had the wrong QT libraries or something.
Well and good, but now I've discovered that some of my clips buzz in Kino. No audio, just a loud buzz. Not all the clips; maybe 10%. They play fine in every other editor and player. They were all captured from the same camera, using the same software, to the same USB drive, in the same DV MOV format. Yet some buzz (but only in Kino) and others don't. I've beaten my head bloody against the wall trying to figure out why.
I tried converting them a dozen different ways with FFMPEG: I either end up with video that sounds fine (but the date/time metadata is gone) or else I keep the date & time, but they still buzz. I tried the map_meta_data option in FFMPEG--no joy.
Right now I'm faced with doing some of my editing in Kino (so I can burn in the date/time) and then exporting those rendered clips to another editor for final editing and encoding with the clips that for some reason Kino can't handle. Royal pain in the butt. Unless someone has a brilliant idea as to how I can get my DV MOV files converting into another DV file and retain the date/time metadata.....?
How to convert Mov video files to Mpeg
By Tintin11 in forum Video ConversionReplies: 4Last Post: 8th Dec 2010, 09:14 -
Convert .MOV to .AVI
By hcs in forum Video ConversionReplies: 4Last Post: 25th Sep 2010, 17:44 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 08:42 -
MOV files, cant open to edit/convert
By haggisuk in forum Video ConversionReplies: 3Last Post: 12th Oct 2009, 11:16 -
How would I convert MOV to AVI?
By Hittz in forum Video ConversionReplies: 9Last Post: 15th Oct 2008, 01:39
