Hello, after Bdto AVCHD has gone through all the steps and finished when i got to the folder where I selected the finished results to be it is empty. This has happened many times, any suggestions where I could be going wrong
I don't recognize the program and can't offer advice on it.
I would suggest checking out multiavchd or the newer updated ripbot264 that has avchd output capability.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Maybe there is another program to shrink HD files to fit onto dual Layer Avchd
I just succesfully shrunk a 18gb mainmovie bluray to bd-9 (duallayer dvd) using bdrebuilder not using the recomended versions and it worked fine you should try it.
Or try the alternative AVCHDCoder, Open your BDMV folder, select your streams(audio,video and subs) to convert then set your resolution bitrate and disc size DVD-DL add it to the queue and press convert.
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 19:09 -
BDtoAVCHD audio problem
By BILL9548 in forum Authoring (Blu-ray)Replies: 0Last Post: 14th May 2011, 14:55 -
WPDNSE folder inside your system Temp folder????
By MozartMan in forum ComputerReplies: 25Last Post: 27th Mar 2011, 08:35 -
BDtoAVCHD
By glimmerman in forum Authoring (Blu-ray)Replies: 5Last Post: 3rd Jun 2010, 11:23
