Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. I'm a Super Moderator johns0's Avatar
    canada
    I got a problem with java on my pc and when i try and use BDSup2Sub the display is very unfocused and the colors bleed,this happened after sp1,anyone else get this problem?Online java is ok.
    I'm also running win7 sp1 and java 6 update 24 and bdsup2sub looks fine.
  3. I'm a Super Moderator johns0's Avatar
    canada
    I found the problem,when i clicked on morphological filtering in the radeon ccc center that caused the issue with the java looking so muddy.
