I need to downsize various HD videos for web uploading. I'm using an older PC but it runs pretty well:
AMD Athlon FX-53 2.4GHZ
1GB pc3200 dual channel
ati radeon x800xt 256mb
10k raptor hard drive
It can actually read a majority of the HD videos you throw at it, albeit with very high cpu usage. The GPU doesn't support dxva hardware acceleration unfortunately. The processor is decent though, given its age, and the corecodec helps it run smoother.
Anyhow, I just need this PC to convert the HD videos to a more compressed Avi or Flv, for web purposes. Which program would you recommend? I prefer to stay away from the mainstream ones likes Vegas or Premiere pro unless they would work well on this machine.
Thx
CAN ANYONE RECOMMEND A 'SMART RENDER' PROGRAM FOR .ts VIDEO FILES?
By QDM in forum EditingReplies: 1Last Post: 12th Jan 2012, 14:49 -
Recommend a batch conversion program for mkv to wmv?
By yoda313 in forum Video ConversionReplies: 2Last Post: 23rd May 2009, 06:58 -
Filter incompatability with older program colorspace
By n4mwd in forum Software PlayingReplies: 4Last Post: 12th May 2009, 10:02 -
Asking advice about HARDWARE for VHS VIDEO conversion projects
By perniente in forum Newbie / General discussionsReplies: 2Last Post: 20th Dec 2007, 18:05 -
What would you recommend for an older person to back up DVDs
By billolmesdahl in forum Newbie / General discussionsReplies: 7Last Post: 21st May 2007, 19:27
