Hi all,
I had a hard disk failure and replaced my hard drive a few weeks ago and installed Windows 7 Enterprise again. Ever since then, I'm unable to render videos properly on Corel VideoStudio. I tried all versions of the program including X2 which I used prior to the hard disk failure. I'm exporting using the same settings 'save as first video clip' as I'm just cutting the video here and there. What happens is the sound gets delayed and all sorts of distortions occur on the video, including green screens when I import on After Effects. I'm not sure what is the problem. I installed Service Pack 1 for Windows 7 and installed Direct X. Should I reinstall my graphics card driver?
Appreciate your assistance.
Haven't installed anything extra. But I think when I installed the trial for VideoStudio X3 it installed SoundTrack Pro and Quicktime which I removed just now.
I tested playback on both VideoStudio, and AfterEffects.
Only using mpeg (2 i think). I take the mpeg, cut and save as first video clip. -
Just realized that the distortions with the sound and video only happen after 15 minutes of the video. I tried some old videos which I edited before the reformat and the same things occur.
Seems to work fine on the old versions now. I reinstalled the HD sound driver. Thanks guns1inger for all your help.
Problem has arisen again after I unknowingly installed VideoStudio x4. Tried reinstalling drivers, same issue. The audio gets delayed and freezes with the video. Only occurs with smart rendering. Didn't happen before, until I installed the dumb x4.
certain videos do not play properly
By julvar in forum Newbie / General discussionsReplies: 5Last Post: 2nd Apr 2011, 15:55 -
Confused about XP cd reformat
By neworldman in forum ComputerReplies: 5Last Post: 22nd Jun 2010, 09:36 -
[FFMPEG] How to properly encode compatible videos for PSP
By squadjot in forum Video ConversionReplies: 1Last Post: 22nd Dec 2009, 22:37 -
Looking for App to Have to Render two videos on screen
By barkster in forum Newbie / General discussionsReplies: 5Last Post: 30th Jan 2009, 09:36 -
Videos not playing properly - Codec Problem - HELP PLEASE
By Man-bear-pig in forum Software PlayingReplies: 1Last Post: 10th Feb 2008, 00:59
