Does anyone know of a ripper that will let you specify the audio gain? I've used WinX Bluray DVD iPad Ripper, but it will only let you set the gain to +9db. I would like to set the gain to +20db. Thanks for any help in advance.
Ripping will only give you an exact untouched copy of the original.
If you are using something that is increasing volume or changing format or decreasing size it is converting.
Obviously whatever it is that you are using is converting so you should be more specific on what it is you are doing and ending up with. -
Thanks for the replies. I bought a bunch of DVDs and want to convert them and view them on my HTC Evo 4G while riding on a loud train during my commute. WinX is easy to use, but does not boost the audio enough. Iriverter does boost the audio to any gain you want, but does not work with a lot of DVDs. I use DVD HD Decrypter to decrypt the DVDs.
I will convert to anything that plays on my Evo. Currently I am converting to .MP4 -
I don't convert anything to MP4 nor do i have a clue what formats an "Evo" will play.
Knowing what formats an Evo will play would help.
Seeing as you own one i would hope you would know.
Audio gain in MultiAVCHD
By Zetti in forum Video ConversionReplies: 0Last Post: 16th Sep 2010, 12:46 -
HELP : FFMpegX PSP Audio GAIN not available ? ? ?
By aerolex in forum Video ConversionReplies: 1Last Post: 17th Dec 2009, 07:33 -
GH1 auto-gain audio
By kippard in forum AudioReplies: 0Last Post: 8th Oct 2009, 02:45 -
Application to lower audio gain of MPEG file?
By headless chicken in forum MacReplies: 6Last Post: 26th Dec 2008, 08:41 -
Audio gain in ffmpeg
By pdec in forum ffmpegX general discussionReplies: 3Last Post: 12th Aug 2008, 06:45
