I have a lot of VHS tapes I have been converting to digital off and on for several years. I capture them to my PC then convert/burn to DVD using ConvertXtoDVD4. Have had mostly good results, not expecting miracles of quality but still good viewing on DVD. Recently the display began showing an increasingly severe leftward drag across the top portion of the display during capture, that remains on the captured digital file.
I have tried 3 different VHS players, 3 different capture devices, capturing using a power USB hub, capturing directly to my PC, and directly to my laptop. But nothing has worked. Would appreciate any suggestions/help anyone can give. Thanks.
Either the tape is severely damaged or perhaps your cables are frayed? Is this happening on all tapes or just one in particular?
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thanks for replying. The tapes and the cables are all in fine condition. It's happening on all tapes and when using 3 different VHS players, 3 different capture devices, using a power USB hub and also direct USB plug into both my PC and my laptop.
Would a time base corrector perhaps solve this problem? It started while I was using a StarTech capture device that had been working fine. Was small at first and I used the masking lines function of my software to mask it out. But over time it became more severe. I thought it must be the capture device failing so bought a different brand. Unfoturnately that didn't solve the problem--distortion is just as severe with the new device as with the old one. So the problem must be somewhere else.
How can I correct severe tearing during VHS capture?
By Sparrowhawk in forum Capturing and VCRReplies: 11Last Post: 3rd Apr 2011, 18:31 -
Cleaning up old family video set to music I captured from VHS
By jesse51786 in forum RestorationReplies: 1Last Post: 27th Nov 2010, 14:13 -
Captured S-VHS format
By Rinsin in forum Capturing and VCRReplies: 24Last Post: 28th May 2009, 13:05 -
captured vhs to ffdshow codec video flashes
By gmanm1 in forum Capturing and VCRReplies: 1Last Post: 13th Dec 2008, 22:40 -
avi videos drag lag freeze. after splitting with solveigmm video splitter
By ezeht in forum EditingReplies: 7Last Post: 29th Nov 2008, 14:06
