Hello! I just bought the LG DN898 from buy.com and I was trying to get it to be Region-free.
I tried to to what was listed in https://www.videohelp.com/dvdhacks?dvdplayer=lg+dn898
twice, once by burning the the .ISO in Nero, and the other time by just burning the folders
from the other .zip file onto a CD-R.
Both times, when I put the CD-R into the DVD drive, it gave me the "! Check disc" message.
I really wanna be able to play my movies, so I hope someone maybe has another answer...
I hope someone can help me with this!
Thank you so much for reading, and in advance for any help you may be able to provide! c:
Did you burn as "Disc at Once" (NOT as "Track at once") and "No multisession"? Those will give you the best chance of success. If you are not using Nero Burning ROM where you can set that stuff yourself but instead using their simple GUI interface then I have no idea what settings it defaults to but they are likely bad.
Do note that others have reported this not working so even if you burn a disc according to my instructions there is some chance that the manufacturer has changed the hardware since this hack worked and it no longer works because of the changes. Good luck. -
Well, I did try it with "Disc at Once", not Track at Once, in Roxio, and also made sure that the "allow more than one recordings" option was not selected, but it didn't work. :c
I'm really sad the hack didn't work for me... I guess they must have changed it.. ;.; Guess I have to keep on copying my own movies in order to watch them on a DVD player. :/
Thank you so much for your help in any case!
Region codes are the stupidest thing in the world though xDDDDD
Region Free Hack Code for Samsung R3 DVD Player P255K
By Scoop in forum Newbie / General discussionsReplies: 3Last Post: 9th Mar 2011, 01:01 -
Honda Odyssey Region Free DVD Hack/Code
By bigidy in forum DVD & Blu-ray PlayersReplies: 1Last Post: 31st Jan 2011, 17:11 -
Recommendations on Region Free w/hack code, player/recorder and blue-ray
By GenieB in forum DVD & Blu-ray RecordersReplies: 0Last Post: 5th Aug 2009, 19:35 -
Bose 3-2-1 region free hack doesnt work see attached keyorder on picture
By monsterag in forum DVD & Blu-ray PlayersReplies: 8Last Post: 27th Jun 2008, 21:46 -
Region free hack/code for pioneer XV-HTD520?
By efirtion in forum DVD & Blu-ray PlayersReplies: 2Last Post: 11th Dec 2007, 12:21
