Hi, I use the Hauppuage HD-PVR to record my video game footage and then upload those raw files to Youtube and its amazing. But recently I started to edit them by adding a watermark so others wont steal my videos, problem is my PC isnt that fast so it can take up to 2 hours just to encode a 15 minute video in HDSo I was wondering is it possible to edit the software that I use 'TotalMedia Extreme' so that I can record footage with a watermark already there? It would save me all the time by not having to edit the videos, or is there another software that will allow me to do this? thanks
No, the processing requirements would be the same so you wouldn't be able to keep up with the incoming data.
Who is stealing your videos, anyway? You could add a voiceover indicating they're yours. -
[Sloved] Hauppauge WinTV PVR-150 capturing using off air cable plug
By Wizard23 in forum Capturing and VCRReplies: 4Last Post: 11th Feb 2011, 22:07 -
Hauppauge HD PVR for PC footage capturing
By Xize in forum Capturing and VCRReplies: 2Last Post: 26th Feb 2010, 11:25 -
Capturing standard broadcasts on Hauppauge HD PVR 1212 - which settings?
By Emanef in forum Capturing and VCRReplies: 2Last Post: 20th Sep 2009, 09:59 -
Hauppauge PVR-350 vs PVR-500MCE
By dphirschler in forum Capturing and VCRReplies: 1Last Post: 11th Mar 2008, 10:04 -
What software for capturing Hi-8 with Hauppauge WinTV 250 PVR USB2?
By boscabru in forum Capturing and VCRReplies: 10Last Post: 5th Mar 2008, 03:19
