I want to backup my dvd's onto my computer just incase they go bad so I still have them is there a program to do this that makes it a one step process or do I need multiple programs to do this.
If you are talking about commercially made dvd movies, then you'll need a decryption/ripping program and a conversion program. You could use DVDFab HD Decrypter to decrypt and rip the movies to the hard drive...it is the free section within DVDFab and will continue to function even after the trial for the main program ends. Convert to avi using something like AutoGK.
If you don't mind paying for a program, DVDFab DVD Ripper can do all these steps: http://www.dvdfab.com/dvd-ripper.htm
I'm not sure why you want to convert the dvds if you are attempting to back them up. Conversion will lose a bit of quality from the originals. You could simply save them as dvd-video instead. For that all you need is DVDFab HD Decrypter.
How to create DVD that retains CC on source file
By Stiff Neck Man in forum Authoring (DVD)Replies: 0Last Post: 13th Jan 2012, 10:12 -
How to create video DVD from DAT file
By abhishekm in forum Authoring (DVD)Replies: 2Last Post: 20th Sep 2011, 13:28 -
Debugmode + Pluraleyes = Unable to create signpost AVI file
By seven_deuce offsuit in forum Newbie / General discussionsReplies: 0Last Post: 18th Apr 2011, 23:12 -
How to create an .avi file with only images and mp3?
By RZ_29 in forum Newbie / General discussionsReplies: 1Last Post: 1st Mar 2009, 11:47 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23
