Has anyone heard of Driver Boost ? It is suppose to help keep your drivers updated. Here is the link to the site
http://www.driverboost.com/index.php
Thanks in advance,
TC
Problem is these days is just because there's an updated driver / package, one should be cautious ... backup those about to be updated so they can be returned if the updated drivers have issues.
I have seen these kind of things come and go for years; allowing some software from (??) to scan your system and decide what is the proper driver can leave you with a system that won't boot. It is always best to go directly to your peripheral's web page, find the proper drivers and install them yourself. Then you know for sure those are the right ones.
You only have their word that there the right one's ... it's still a chance they may not be ... it's happened a few times.Then you know for sure those are the right ones.
If it ain't broke, don't fix it.
I do not update drivers just for the sake of it.
I would certainly not trust a 'one-click' program/web site to be more disconcerting than my own eyes.
These exist for people who simply do not know what is inside their PC so they trust the unknown to update the unknown. -
Which is the best driver update software?
By skorpinok in forum ComputerReplies: 13Last Post: 23rd Dec 2011, 00:33 -
Driver finder software W7
By neworldman in forum ComputerReplies: 5Last Post: 28th Jul 2010, 22:24 -
Driver backup software
By Tbag in forum ComputerReplies: 2Last Post: 2nd Mar 2010, 19:10 -
Pinnacle Card (model) + driver software
By dinkob in forum Capturing and VCRReplies: 3Last Post: 3rd Aug 2008, 19:09 -
I have the driver for my DVCII - now I need software. Can anyone help?
By Haopengyou in forum Capturing and VCRReplies: 0Last Post: 13th May 2007, 11:41
