Hi - I'm exploring mencoder for making a bunch h.264's in a batch...
I understand that when making H.264's, mencoder can either use libavcodec's libx264 library (which i believe is part of the ffmpeg project), or it can use it's own x264 encoding library... do I have that distinction correct?
My impression is that the libavcodec route is a lot more flexible, provides tons of option control, etc. About 381 options, judging by:
http://git.ffmpeg.org/?p=ffmpeg.git;a=blob;f=libavcodec/options.c;h=e4bc8a6226f4c79a24...s/heads/master
Since I don't think I'm going to need that kind of fine-grained control, I'm thinking of using x264 in mencoder directly, especially because it provides easier-to-use profiles and so forth.
Is there any dramatic difference in quality going one route or the other, considering that i wouldn't be expert in choosing my encoding options with libavcodec? I would just do some test encodings but it would take so long to sort out all the libavcodec options that I thought it might be more straightforward to just ask. Google'd around and didn't come up with anything...
Thanks!
-Casey
Results 1 to 1 of 1
libavcodec x264 profiles
By Spearmint in forum ProgrammingReplies: 0Last Post: 2nd May 2011, 20:57 -
mencoder x264 issues
By tommiy in forum Video ConversionReplies: 3Last Post: 19th Sep 2010, 02:14 -
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 08:12 -
failed dvd deinterlacing with mencoder x264 encoding. help
By link626 in forum DVD RippingReplies: 9Last Post: 3rd Jan 2010, 14:59 -
ffmpeg mencoder x264
By mrcoolekin in forum Portable VideoReplies: 1Last Post: 16th Jan 2008, 07:49
