Hello. I seem to have encountered a problem with some subtitles I've extracted. It's from an anime I've gotten, and it's in mkv format. The subtitles play fine when it's in the mkv format. I convert them into mp4 format to watch them on my PS3. Anyway, I extract them with MKVExtractGUI and I open the episode in XviD4PSP to convert. I add the subtitles in and then preview to make sure the subtitles are correct. They start off fine at first, but during the opening the subtitles that are supposed to play after the opening play during the opening and it throws the entire episode off.
I opened the subtitles in Aegisubs and it said that everything is timed properly. There's line 1 that has nothing in it from 48 seconds to 2:44, and line 15 starts at 49 seconds in but line 1 is supposed to stop it from appearing, correct? So, I was wondering if anyone knew how I could fix this. Any help would be greatly appreciated. Also, I've never encountered this problem until recently.
Results 1 to 1 of 1
Subtitle timing problem, DVD created using DVD Flick
By Vianty in forum Authoring (DVD)Replies: 8Last Post: 28th Apr 2010, 02:33 -
mkv2vob subtitle timing problem
By HeroSmero in forum Video ConversionReplies: 1Last Post: 5th Jan 2010, 18:31 -
Problem with DVD subtitle palette extracted with SubRip
By picrade in forum SubtitleReplies: 0Last Post: 14th Jun 2008, 18:48 -
timing off on extracted subtitles?
By ecc in forum SubtitleReplies: 0Last Post: 24th Feb 2008, 06:37 -
mpeg file subtitle timing problem
By ecc in forum SubtitleReplies: 5Last Post: 25th Jun 2007, 07:07
