Every time I try to use this it fails to extract audio and aborts. I used inspect.exe and it said everything was OK except for FFDSHOW: 3721 and Haali. I downloaded the latest version and installed them, but they appear to be the same as I had installed before. inspect.exe still says not recommended version on both. What am I doing wrong? I'm very new to this. It's probably some setting I need to change, but I'm not sure which one. Thanks.
Results 1 to 9 of 9
PLEASE do not ask questions in tools sections. I deleted it.
Does it fail with all your blu-rays? How do you rip? -
You should use the versions recommended by the author of BDRB, available partway down the page here:
http://forum.doom9.org/showthread.php?t=143716
It would help if you posted the entire log with the specific error.Pull! Bang! Darn! -
I am. I downloaded everything that page said to with the links provided as well as everything that unpacked with the latest version of BD Rebuilder. I will post the error next time I get it, but it will take 2-3 days for the program to get to where it errors out. I need to make some upgrades on my PC. I just built it a year ago, but had no idea how much more juice I would need to compress blu-ray.
You need a dual-core at least to make encode times bearable. With BDRB that means overnight at "Good" (fastest) speed.
Sometimes a simple uninstall/re-install fixes errors like that. But you have to: uninstall, reboot, delete the program folders for ffdshow, haali, avisynth. Run a registry cleaner like CCleaner. Re-install. There have been reports that haali in particular can get corrupted, and it's necessary to delete the program folder and clean the registry before re-install.
Good luck.Pull! Bang! Darn! -
I have an Athalon 64 dual core. I'm contemplating buying a quad though.
I am having the exact same issue. I successfully ripped my first BD to disc and it plays on my PC. However, the movie alone is 38.89 GB so I have to get it down to a 25GB BD-R in order to burn. So, thus far my issue is with BD-RB and the fact it fails to extract the audio and aborts. Please help!!!
BD Rebuilder failure
By pepegot1 in forum Blu-ray RippingReplies: 5Last Post: 18th Dec 2011, 13:25 -
Audio Issue with BD-Rebuilder BD-RBV03804
By alejandroricardo in forum Authoring (Blu-ray)Replies: 5Last Post: 19th Jul 2011, 15:49 -
Unable to extract audio - BD-Rebuilder aborts
By mobie29 in forum Blu-ray RippingReplies: 4Last Post: 7th Apr 2011, 10:19 -
Audio issue when shrinking blu ray to dvd using BD-Rebuilder or DVD-Rebuild
By sharjohn in forum Blu-ray RippingReplies: 2Last Post: 1st Dec 2010, 13:36 -
BD REbuilder ERRor - Error in attempt to extract audio/subs.
By ajhansen91 in forum Blu-ray RippingReplies: 1Last Post: 26th Mar 2009, 15:39
