http://caffeine.iem.nctu.edu.tw/~far/KISS.asf
Pls right click and save it and try to convert it to mpeg.
I have followed the guide on the right and still can't open it with
Tmpegenc 1.2a or 2 and virtualdub 1.3c
Also I have tried setting direct show filter priorty to 1 or higher,still no luck.
Anyone can open the video using any encoder,pls tell me.
I downloaded only a small part. Then I loaded it into TMPGEnc 2.53plus and converted it to MPEG, no problems at all...
Thanks Truman,
It works!
I have a old computer P350,so I am afraid that the newest Tmpgenc
can't work.But it actuallyworks, just takes half an hour to convert that 8 min asf file.
Thanks again, this is a great site!
Convert multiple mpeg2 to wmv with command line!!! Help pls!!
By orlroc in forum Video ConversionReplies: 5Last Post: 15th Dec 2009, 23:18 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Pls Help convert my 3gp file to mpg or avi
By Nanflexal in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 15:58 -
Pls recommend format and specs to convert you tube mp4 files for archival
By perfection in forum Video ConversionReplies: 2Last Post: 6th Jan 2009, 02:32 -
Convert to .mtv?
By calande in forum DVD RippingReplies: 2Last Post: 2nd Jan 2009, 09:57
