I'm tired of trying to figure out how to calibrate my computer monitor for video editing and want to go ahead and purchase a hardware calibration device. I found one called the Huey that isn't too expensive. What suggestions do you have based on your experiences? Is the Huey good? Or is that only for photo/print work? Someone else told me to put the monitor on the factory settings and then just adjust the brightness according to the appropriate test pattern, but to leave all the other settings alone...
Monitor calibration device suggestion?
By sdsumike619 in forum EditingReplies: 18Last Post: 4th Mar 2011, 07:33 -
The device USB 2861 device could not be opened
By Fabis94 in forum EditingReplies: 5Last Post: 20th Nov 2010, 14:40 -
HD Pvr 1212 - device is not connected - can't use device in arcsoft softwar
By yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 18:22 -
Hardware advice, video card & monitor, DVI or VGA ??
By Noahtuck in forum ComputerReplies: 7Last Post: 12th Jul 2009, 01:58 -
Looking for a device to output signal as second (or mirrored) monitor to TV
By ViRaL1 in forum Off topicReplies: 0Last Post: 29th Aug 2007, 12:33
