please could some nice person make this portable i would love you so muchCode:https://www.videohelp.com/download/SUPERsetup201146.exe
SUPER is a GUI to FFmpeg, MEncoder, MPlayer, x264, MusePack, Monkey's audio, Shorten audio, TAK audio, True audio, WavPack, the libavcodec library & the theora/vorbis RealProducer's plugIn. I doubt you will find a portable version.
But your question would be better asked at the developer site: http://www.erightsoft.com/SUPER.html Though I didn't see anywhere there to communicate with the author.
You can find a few portable converter programs like VirtualDub portable: http://portableapps.com/apps/music_video/virtualdub_portable -
The older versions basically were portable. If you just copied the contents of the folder SUPER installed into onto a USB drive, you could run it anywhere. I don't know if newer versions install libraries elsewhere, but it would take all of two minutes for you to test it for yourself.
That said, I find XmediaRecode to be a far superior converter to SUPER, and it comes in a portable version as well as an installed version. Just pick your download from the author's site.Read my blog here.
User guide for super video converter
By ocko in forum Newbie / General discussionsReplies: 2Last Post: 20th Aug 2012, 06:32 -
Super Video converter... browser hijack
By ranchhand in forum Newbie / General discussionsReplies: 2Last Post: 21st Mar 2011, 06:16 -
Help converting files using Super Video Converter
By celestialwolven in forum Video ConversionReplies: 3Last Post: 17th Aug 2009, 03:00 -
Alternative to super video converter
By a1i3n777 in forum Video ConversionReplies: 6Last Post: 8th Nov 2008, 06:33 -
any video converter/super font size
By MasterRoshi in forum Video ConversionReplies: 4Last Post: 19th Oct 2008, 15:48
