Hello,
I'm rather new to the topic and sorry if this basic question has been answered numerous times (I did a search in the forum but could not easily find an answer).
I'm looking for a freeware that would allow me to convert VOB files (the ones produced using DVDFab) into a single DivX while keeping the original DVD menus (which I think DivX supports but ...). Ideally this tools would also allow me to choose all the other parameters like bitrate, framerate, ...
If that is not possible using DivX, is there another format that I should consider ?
Tx in advance,
Xtof.
Yes, you can make a .divx with menus but you have to do everything manual. No automatic dvd to .divx with menu software.
Just make an .iso and play with vlc.
Creating a DVD Menu for multiple divx files without converting them
By LGT in forum Newbie / General discussionsReplies: 23Last Post: 21st Jul 2010, 14:04 -
How do convert Divx files to play on my DVD player?
By Solehawk in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:37 -
How to create a DVD using multiple DIVX/XVID files with Menu
By Amourek in forum User guidesReplies: 2Last Post: 2nd Mar 2009, 08:57 -
Making a DVD menu from .VOB files created by FAVC?
By whatever911 in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2009, 03:13 -
Dr. DivX converts large VOB files into tiny unusable divX files
By texas1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Aug 2007, 21:44
