I used DGIndex to create a .d2v file from a .vob file. With the .d2v file I was able to use VirtualDub/AviSynth to clean up the interlace with TomsMoComp. So far everything is great. TomsMoComp did what Handbrake was unable to do. Now my problem is I don't know how to put back together the audio (DGIndex saved it as a .separate .ac3 file) and the video.
I can do it without the TomsMoComp with a script like this:
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\DGDecode.dll")
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\NicAudio_204\NicAudio.dll")
video = MPEG2Source("E01.d2v")
audio = NicAc3Source("E01 T80 3_2ch 448Kbps DELAY 0ms.ac3")
AudioDub(video,audio)
However, I lose my TomsMoComp.
My script for TomsMoComp look like this:
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\Avisynth_2.5\TomsMoComp.dll")
clip = MPEG2Source("E01.d2v")
return clip.TomsMoComp(1,5,1)
How can I use this script and and audio to it? Or do I need to do something else entirely?
Results 1 to 11 of 11
add it after , or stick it onto the video with "."
video = MPEG2Source("E01.d2v").TomsMoComp(1,5,1)
or
TomsMoComp(1,5,1) -
Can it be mixed? There are parts that definitely follow the 3 progressive frames/2 interlaced frames sequence with motion, but at the beginning there's a closeup of a person speaking and there is one particular segment where at least 6 frames in a row are interlaced (horizontal lines on the movement).
I tried using decomb with detelecine, default settings and they did nothing on the closeups of the person speaking. And I tried using default deinterlace, again with no results. I didn't really understand Handbrake's documentation well enough to change anything from the default values. -
yes it can be mixed
I would recommend using adaptive field matcher (TFM from TIVTC package in hybrid mode) ; so things like cadence breaks are handled better -
Hard to say, it's going to depend on the source and settings. If you think it's ok, then don't worry about it
But if it's deinterlacing 3:2 sections without decimation, you're going to get dupes (jerky playback)
If this is a primarily telecined 3:2 film source with different sections that are video, you would normally follow up TFM(some settings) with TDecimate(some settings) to decimate the dupes .Last edited by poisondeathray; 1st Mar 2011 at 16:22.
It didn't appear to be jerky in the preview in VirtualDub or WMP. But that is something I will look out for with future conversions.
Can I be an even bigger newb, and ask for a recommendation on a good encoder? I just found what seems to be a good guide for using MeGui with .avs scripts to encode to .mp4, was thinking of trying that. Or is there a plugin for VirtualDub?
Thanks again for your help!! -
encoder for what? h.264 ? xvid ? mpeg2 ?
there is only 1 free h.264 encoder, that's x264 encoder. Both megui and handbrake are GUI's for it
megui should work fine, as should vdub . You can access x264 in vdub directly through the vfw version of x264 , or use vdub's external encoder feature
DGIndex says 100% Video, but MeGUI Avisynth analysis says Source Type Film
By Simcut in forum DVD RippingReplies: 11Last Post: 9th Mar 2012, 17:10 -
Audio Synch Problems AVISynth to Virtualdub
By magillagorilla in forum AudioReplies: 15Last Post: 20th Sep 2011, 00:05 -
AviSynth & VirtualDub - Comfortable ways to create avs-files?
By klischee in forum EditingReplies: 7Last Post: 28th Oct 2010, 17:20 -
HDTV to DVD using DGIndex/AviSynth losing frames
By gadgetguy in forum Video ConversionReplies: 13Last Post: 3rd Sep 2008, 17:12 -
any demuxers other than dgindex create d2v files for avisynth?
By ecc in forum Video ConversionReplies: 3Last Post: 4th Dec 2007, 11:43
