I cannot get Virtual Dub, or WMP to open my script. I have installed AviSynth 2.5.8 to C:\Program Files\AviSynth 2.5, extracted (no installer exe) DGMPGDec 1.5.8 to C:\Program Files\DGMPGDec, and extracted (no installer exe) Virtual Dub 1.9.11 to C:\Program Files\VirtualDub. I then cut the DGDecode.dll from the DGMPGDec folder and pasted it to the plugins folder of AviSynth. I opened a DVD Rip .vob file in DGIndex to make a .d2v file, saved it in C:\Movies as VTS_01_1.d2v. Here is my script:
LoadPlugin("C:\Program Files\AviSynth 2.5\plugins\DGDecode.dll")
MPEG2Source("C:\movies\VTS_01_1.d2v")
Any Ideas? Virtual Dub sits there for a few minutes then I get a message screen that says:
AviSynth open failure:
Evaluate: System Exception - Access Violation
(C:\Movies\E01.avs, line 2)
All three programs were downloaded from author sites.
Nevermind, I figured it out. My original .vob files were on a USB stick. I moved them to C:\Movies, made a new .d2v file, saved in C:\Movies, removed the path from line 2, and wham-bam. It works.
Why do I get the feeling this is bait set up by the other group and I'm falling for it? Oh well, whatever. So long as it helps me...here goes...
Charlie, I'm having the same trouble, but my vob files ARE saved in the computer. Virtualdub will NOT open my d2v file no matter what.
Any suggestions? -
Is your avs script saved in the same location as your .d2v file? It could be a path problem.
The script doesn't have to be in the same location as the d2v file if you use a full pathname in the AVS script. Do not delete, move, or rename the MPG file because the d2v file is only an index. dgdecode.dll reads frames from the MPG file using the d2v file simply as a map to quickly locate the frames.
How to open AVC and AAC in VirtualDub (AviSynth/DShowPlugin)?
By klischee in forum EditingReplies: 37Last Post: 8th Aug 2014, 02:38 -
Lost ability to use Avisynth script to open .flv file with virtualdub.
By DaneClark in forum Video ConversionReplies: 4Last Post: 20th Feb 2011, 11:33 -
Avisynth question open failure FF3TdGPU.dll
By duster1234 in forum Video ConversionReplies: 4Last Post: 15th Oct 2008, 07:29 -
By rocky12 in forum Newbie / General discussionsReplies: 11Last Post: 29th Jul 2008, 20:35 -
Avisynth open failure for cropping
By php111 in forum Newbie / General discussionsReplies: 51Last Post: 26th Mar 2008, 12:24
