    Dec 2008
    Canada
    Hi Guys:
    I have a perplexing problem. When I burn an avi to dvd with discuggler, sometimes the file will be truncated. Verify is turned on in Discjuggler and Discjuggler says verify is OK. When I put the same avi in Dvd Authoring Works and make a Divx Ultra, everything is OK. All files are less than 2 Gb going on a 4.7 Gb dvd.
    I got the idea that this problem may be associated with file size in some way but have not yet tried to check that out.
    Any ideas?
    Lorne
    Mar 2008
    Don't use Diskjuggler. Try Imgburn in "write files/folders" mode.
    Jun 2005
    Vermont
    or try Burnaware Free. I've tried many & this is now my favorite. Easy & fast.
    Dec 2008
    Canada
    Thanks guys.
    I will try and report back.
    Thanks again.
