  1. Hi , i basically just need the sound from some AVI and MPG files , which program can i use to just strip out the sound and for it to leave me a MP3 ? ideally a program that will let me also set the quality as i dont want the mp3 to be big , medium quality would be fine.
    Use a demultiplexer. Like the very basic Pazera Free Audio Extractor.
  3. Wow thank you for your super fast reply , i shall take a look ty.
  4. p.s , i have some mp3 files that i'd like to reduce in Size/space , do you know of a good batch type program for running a whole load of mp3 files through ? leaving me with all the processed files and originals intact.
  5. Originally Posted by soulbug View Post
    FormatFactory is one I use regularly (freeware). It does everything.
    Read the description on here on videohelp before you download.
    Warning! Format Factory installs K-Lite Codec pack that might cause problems with other video software on your computer.
    I use the codec pack anyway so I've never had problems with it, but then, I use a portable build I made myself so it's self contained.
  6. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    foobar2000
    dBpoweramp
    CDEx
    Can all do batch audio conversions.
