  1. I've read all I can find on this site regarding frameserving from VDub to TMPEGEnc. I got to the point where I select the video.vdr.avi file in TMPEGEnc and then it would just sit there, cursor looking busy. After a while I hit CTRL-ALT-DEL and it said TMPEGEnc (Not Responding). Is this normal?
    Also, now when I select the .vdr file I'm getting the can not open or unsupported error message. I have already made the adjustments in environmental settings, changed them all around and can't get it to work again.
    I'm running a Gateway Pentium III 1000 with Windows ME, if this makes any difference.
    TIA for your help...
    Mike
    Jan 2002
    Australia
    I don't know about your second problem, but the hanging thing happens to me everytime I put up a new version of TMPGEnc. Then I have to go and fix the environment settings, and it all works fine.
    Come to think of it, I did have something like your first problem a couple of times, but it was due to my stupidity! I often use the same file names, and for various reasons sometimes end up in the wrong directory, so I was pointing to a file which was NOT a current VD frameserve (hence the error).
    Regarding the environment settings, the 'how to' says to lower the priority of the Directshow reader, but I have found (and I'm sure it's what used to be in the instructions) that it is the AVI2 reader that should be raised. Works for me anyway.
    Good luck
    Aug 2001
    Finland
    Have you activated VirtualDubs frameserver (proxyon)?
    Feb 2001
    Berlin, Germany
    If you are running winME, you do not need the proxy mode, you do not need to rename it to avi. Just make sure, you installed the handler and open the *.vdr in TMPG.
  5. Thanks for all your help, but so far, still having the same problem. I'm running TMPEG V 2.52.34.129 core version 1.83.129.
    Virtual dub 1.4c
    I've turned proxyoff. Tried without .avi extension.
    I have AVI2 reader top priority, followed by Directshow reader.
    Any other thoughts?
    Thanks again,
    Mike
  6. Hollywood_Mike:
    Go into the directory that you installed VirtualDub into. There should be a file in there called AUXSETUP.EXE.
    Run it.
    In the auxillary setup menu, choose Install handler.
    That's it.
    When you go to start your frameserver, use a .VDR extension for your file - mummy.vdr, for example.
    In TMPGEnc, load the mummy.vdr file and everything should be ok.
  7. Well, I think this weekend, I'll re-install both Virtual Dub and TMPEG. I don't know what the problem is, but I've tried all suggestions, and frameserving just seems to hang my computer.
  8. I'm not sure what it was I did to make it work, but I finally got frameserving working. I re-installed both VDub & TMPG, but it still would hang my computer. Then I tried a frameserve from one copy of VDub to another, and that worked. So I tried TMPG again, and it's been working since.
    Thanks everone for all the help, and hopefully this can help someone else having problems.
    Mike
