hi there
I've got a lot of video files that I've recently picked up and all of them have a horrible combing effect on them which makes them nigh-on unwatchable. I've tried them on things like Media Player Classic, VLC, DIVX Player, etc. and they all seem the same. Is it more likely that the files have been encoded badly or is there maybe a setting in any of the players that will fix it? I've pasted the MediaInfo details of one of the files below...
cheers
General
Complete name : F:\video.avi
Format : AVI
File size : 502 MiB
Duration : 46mn 46s
Overall bit rate : 1 502 Kbps
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 46mn 46s
Bit rate : 1 300 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.169
Stream size : 435 MiB (87%)
Writing library : XviD 1.1.0 (UTC 2005-11-22)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 46mn 46s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Delay relative to video : 26ms
Stream size : 64.2 MiB (13%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.00 video frame)
Title : Audio Stream
Writing library : LAME3.92
How to remove annoying "Press Esc to ..." message in Flash Video
By roma_turok in forum User guidesReplies: 517Last Post: 23rd Oct 2017, 10:09 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
DVD from .mts file with "combing" effect.
By HF20_user in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2009, 14:28 -
Gray "!" iTunes 8 annoying song location issue...
By Nintendo Fan in forum ComputerReplies: 12Last Post: 14th Jun 2009, 10:38 -
Philips DVP 3140: Annoying black bar after pressing "play"
By tt-jones in forum DVD & Blu-ray PlayersReplies: 0Last Post: 19th Sep 2007, 22:29
