Hello, new here.
I have a Samsung DVD player model P255K mfg'ed in Region 3. I tried to use the hack code that was posted in the DVD Hacks list section but it didn't work for me. Here is the code that I tried to use:
1: Turn DVD player on, with NO DVD in the tray.
2: Press Repeat on remote control (bottom right key)
3: Enter 76884
4: Press 9
5: Open tray, close tray
6: Turn off DVD player, turn it back on.
Does anyone have another code that I might try for this player?
Look at the suggestions here:
http://www.dvddemystifiziert.de/codefree_en/samsung.html
If no go, perhaps the firmware of your player has been revised by the manufacturer
to disallow it. -
Dave,
Thanks for the reply! Here are the instructions that was at the site link that you provided:
Power on your player with no disc in the tray- Press REPEAT for 5 seconds
- Enter the corresponding combination for your current RC (see top of the page)
- Current RC should be displayed
- Press the button for the desired RC (9=multi-region)
- (Press OPEN)Power off your player
- Region codes:
- RC 1: 2, 9, 3, 3, 4
- RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8)
- RC 3: 5, 6, 7, 3, 2
- RC 4: 7, 6, 8, 8, 4
- RC 5: 5, 3, 8, 1, 4
- RC 6: 2, 4, 4, 6, 2
The player is mfg'ed for R3 use. I'm not sure what they are referring to here in step 3 of the instructions.
This player was bought in 2005 when the model was new.
[edit] I got it understood now *duh* haha, thanks again for the link! -
Dave,
Thanks for the link for the Samsung player. My friend overseas in R3 told me that this code worked.
Region free hack samsung dvd player ht-d453hk
By nhe in forum DVD & Blu-ray PlayersReplies: 4Last Post: 1st Apr 2014, 21:31 -
need region free hack for samsung dvd player p171
By oztib in forum DVD & Blu-ray PlayersReplies: 23Last Post: 9th Aug 2010, 08:21 -
Region Free Code for Samsung DVD-P190?
By Hypnotised in forum DVD & Blu-ray PlayersReplies: 4Last Post: 19th Jan 2010, 13:00 -
Recommendations on Region Free w/hack code, player/recorder and blue-ray
By GenieB in forum DVD & Blu-ray RecordersReplies: 0Last Post: 5th Aug 2009, 18:35 -
region free code for Samsung DVD HD 931
By hooroousa in forum Newbie / General discussionsReplies: 1Last Post: 22nd Aug 2008, 10:18
